branding iron
Forum topic by newwoodbutcher posted 12-12-2017 12:51 AM 632 views 0 times favorited 6 replies Add to Favorites Watch
View newwoodbutcher's profile
newwoodbutcher
780 posts in 3083 days
12-12-2017 12:51 AM
I sometimes use a branding iron to sign my work, I have the Rockler electric branding iron. It works well and I have no issues with it. I ordered one for a woodworking buddy Christmas gift and they sent me the non electric version that requires a torch by mistake. I’m wondering if I should return it, and reorder the electric version, If I do I’ll most likely not get it in time for Christmas. Have any of you used the non electric version? Are you happy with it? Any tips?
-- Ken
View hairy's profile
hairy
2783 posts in 3765 days
#1 posted 12-12-2017 01:55 PM
Mine is not electric. My avatar is my branding iron.
Either one will take practice. I use a torch, it is not a problem. I’ve never used an electric. One thing I like is that I can take the rod out of the handle and use it on my lathe or drill press.
-- My reality check bounced...
View PPK's profile
PPK
1244 posts in 1043 days
#2 posted 12-12-2017 02:23 PM
Either one will take practice. I use a torch, it is not a problem. I ve never used an electric. One thing I like is that I can take the rod out of the handle and use it on my lathe or drill press.
- hairy
+1
-- Pete
View splintergroup's profile
splintergroup
2499 posts in 1456 days
#3 posted 12-12-2017 03:52 PM
I also have the Rockier torch-heat version.
It works fine, but as Hairy points out, practice helps.
It takes a minute or two to heat up, depending on the torch and you want to brand a test scrap first to be sure the heat is correct ( I usually need to heat it up a tad further than I thought).
After the heat is correct, I can usually brand 2-4 items in succession before needing to heat it back up.
I look at the choice as am I doing production branding or one-offs?
The electric sure would be easier, but I’m cheap the way 8^)
Using the drill press is a fantastic idea!
newwoodbutcher
#4 posted 12-12-2017 04:18 PM
Thank you both.
-- Ken
View John Smith's profile
John Smith
1532 posts in 396 days
#5 posted 12-17-2017 12:38 AM
I also have the non-electric iron.
the instructions that came with mine (back in 1985) is when you heat it,
heat with the flame on the back side of the brass block – not the front.
reason being is that with the flame constantly on the graphics, the crispness
of the letters will degrade over time and you will have less than favorable results.
-- I started out with nothing in life ~ and still have most of it left.
View HorizontalMike's profile
HorizontalMike
7770 posts in 3147 days
#6 posted 12-17-2017 06:37 PM
I use the Lee Valley 2-line electric version. I find this sensitive to the hardness of the wood, and would suspect that using the torch non-electric version may be more efficient on really hard dense woods…
