Pre-finished plywood to brick. What glue to use?
Forum topic by Lloyd Davies posted 03-05-2011 07:30 AM 22612 views 0 times favorited 21 replies Add to Favorites Watch
View Lloyd Davies's profile
Lloyd Davies
116 posts in 3352 days
03-05-2011 07:30 AM
Topic tags/keywords: maple joining brick glue liquid nails
Hi all,
I would like to attached a 3 ft x 10 ft pre-finished 1/2 inch maple plywood to partially cover a brick fireplace. Does anyone have any suggestions as to how to do it? I was thinking of some kind of “liquid nails” type glue.
Thanks in advance, Lloyd
-- Northern California http://www.lloydus.com
21 replies so far
View Don's profile
Don
517 posts in 3099 days
#1 posted 03-05-2011 07:51 AM
Liquid nails will probobly hold it fine but I would use some concrete screws just because it makes it a whole lot easier to undo later on it you need to.
-- Don - I wood work if I could. Redmond WA.
View dpwalker's profile
dpwalker
273 posts in 2857 days
#2 posted 03-05-2011 10:47 AM
I used silocone adhesive for plywood to brick on a wall. It came in a tube like caulk. Didn’t use any fasteners. The wall has been up for about 7 years with no problems.
-- You have not really lived until you do something for someone who can never repay you.
View ScottN's profile
ScottN
261 posts in 2705 days
#3 posted 03-05-2011 01:04 PM
You could glue( what dpwalker described) and anchor screw some 1×2’s 16” oc. Then pin nail plywood using a finish nailer.
-- New Auburn,WI
View David Grimes's profile
David Grimes
2078 posts in 2666 days
#4 posted 03-05-2011 04:23 PM
So your pre-finished piece is going directly to the masonry only and there is no framework or sleepers desired. Having done this many times, I will recommend that you glue (Power Grab, Ply Seam Seal, or Liguid Nails) and screw (Tapcons). If the tapcons would ruin the party (going through the finished piece), then go with one of the proper mastics.
-- If you're going to stir the pot, think BIG spoon or SMALL boat paddle. David Grimes, Georgia
Lloyd Davies
#5 posted 03-05-2011 07:32 PM
@david grimes. What do you mean “one of the proper mastics”?
I am wanting to go screw less for aesthetic purposes.
View reggiek's profile
reggiek
2240 posts in 3296 days
#6 posted 03-05-2011 07:40 PM
A good construction grade adhesive like Liquid Nails….there are several kinds they sell at the borg that come in caulk gun cartridges. I have used that to stick things to masonry and stucco. There are also masonry nails….or screws (you need a good hammer drill for the screws).....Depending where you are you also need to look at code for proper attaching….if it is wet area you definitely need to use a weather proof adhesive.
Remember that wood and masonry expand and contract differently….you need to make sure your adhesive is plyable….contains silicone or similar.
David Grimes
#7 posted 03-06-2011 03:09 AM
Lloyd, Sorry, Mastic = glue or adhesive…. of which there are many kinds, but only certain ones are appropriate such as “(Power Grab, Poly Seam Seal, or Liguid Nails)” to name a few. Reggiek is correct that bi-material expansion may eventually let loose if the mastic/glue/adhesive chosen does not adhere to both surfaces (wood and masonry in your case) AND that it has some flex so that the one that moves the most doesn’t let loose of the other material (with the adhesive staying with the one that bonds best with the adhesive).
One other factor to consider is the chosen adhesives property of initial tack or grab. I threw Power Grab in for that reason as it does just that.
I have used all three of the ones I listed and have had intended results with each.
Regards,
David Grimes
View HallTree's profile
HallTree
5664 posts in 3793 days
#8 posted 03-06-2011 03:10 AM
Check-out:
http://www.thistothat.com/
-- "Hold on to instruction, do not let it go; guard it well, for it is your life" Solomon
View Gregn's profile
Gregn
1642 posts in 3009 days
#9 posted 03-06-2011 04:57 AM
I have glued wood to concrete with polyurethane glue (gorilla glue) with good results.
David Grimes
#10 posted 03-06-2011 05:09 AM
Halltree, Nice site (ThistoThat.com), but couldn’t help but note that brick, block and/or mortar are not listed.
Not to beat an answered horse to death, but technically it would probably be best to prime the brick with an enamel masonry filler and/or high adhesion primer, let dry, then use nearly anything to bond the brick to the wood. Probably overkill.
We’ve used the high adhesion primer from Sherwin to get paint to stick to laminate (without sanding or even scuffing required) in a shoe department remodel at one of the big boxes at the local mall. It was and is there until they do another color change. No peeling or delamination at all.
FWIW
View allmyfingers's profile
allmyfingers
40 posts in 2672 days
#11 posted 03-06-2011 04:49 PM
why would you want to cover a fireplace in the first place?
-- I cut it 3 times and it was still too short?!?
View thewoodmaster's profile
thewoodmaster
62 posts in 3218 days
#12 posted 03-06-2011 04:59 PM
I would use PL Premium. Both HD and lowes sell it. I’ve used this glue on brick and it holds well.
-- dan "insert pithy woodworking coment here"
View bb71's profile
bb71
42 posts in 3072 days
#13 posted 03-06-2011 05:04 PM
+1 on the PL Premium. Its excellent construction adhesive. Use it all the time.
View Pop's profile
Pop
427 posts in 3972 days
#14 posted 03-06-2011 08:56 PM
Just a note of caution. When you mix masonry & wood you can have a termite problem.
Pop
-- One who works with his hands is a laborer, his hands & head A craftsman, his hands, head & heart a artist
HallTree
#15 posted 03-07-2011 01:00 AM
David, thanks for the heads up on ‘couldn’t help but note that brick, block and/or mortar are not listed’ on the post I made about ‘This to That’. I got on their site and shared your comment .
