Portable Handheld Electric Planers
Forum topic by ChicagoHiker posted 12-11-2017 04:24 PM 580 views 0 times favorited 11 replies Add to Favorites Watch
View ChicagoHiker's profile
ChicagoHiker
53 posts in 2006 days
12-11-2017 04:24 PM
Topic tags/keywords: planer
I’m curious what people here think of portable handheld electric planers. I’m thinking they might be useful on pieces that are too wide for my benchtop planer or too short and am likely to end up with snipe.
Thanks for any suggestions!
-- Paul Segedin, Chicago, IL http://urbanprairiedesign.com/
11 replies so far
View MrRon's profile
MrRon
5193 posts in 3445 days
#1 posted 12-11-2017 06:16 PM
I have an old hand planer that I’ve owned for around 40 years. It’s only been used a few times and it still works. I just can’t find a project that requires a hand planer. I used it about 2 years ago to rough out some stock. I think they were mainly used by house builders for such purposes as fitting doors in frames. Because of their aggressive nature, I don’t think they would be suitable for fine furniture making, especially where expensive hardwoods are used.
View Loren's profile
10477 posts in 3849 days
#2 posted 12-11-2017 06:39 PM
They can be used for flattening slabs. The
blade corners leave ridges. I had one where
I ground off the corners.
I find hand planes can be used with more
sensitivity.
View LesB's profile
LesB
1863 posts in 3644 days
#3 posted 12-11-2017 06:50 PM
I inherited one from my Dad but would not even consider using it for planing a flat board for multiple reasons I won’t even bother to elaborate here. I have used it primarily for edge planing door edges for a final fit Even then a hand plane usually works better because I have more control of the cut.
For boards too wide for the planer I use hand plane or a drum sander.
Boards that are two short can be run through the planer if you build a sled to hold them, or you can attach longer boards on each side with hot glue, run it through and then pop the side boards off.
-- Les B, Oregon
View BurlyBob's profile
BurlyBob
5983 posts in 2467 days
#4 posted 12-11-2017 09:04 PM
I bought one thinking it would be the answer to a lot of problems. The worst waste of $125. It’s only good for rough carpentry and that might be a little to kind. Honestly don’t waist your money.
View Texcaster's profile
Texcaster
1287 posts in 1875 days
#5 posted 12-11-2017 09:13 PM
Power planes are scrub planes that mean business! Or they can be very well mannered indeed.
http://lumberjocks.com/Texcaster/blog/53473
-- Mama calls me Texcaster but my real name is Mr. Earl.
View PPK's profile
PPK
1199 posts in 1010 days
#6 posted 12-11-2017 09:33 PM
I own one and it’s a VERY important tool to have when you’re a cabinet maker/installer… I use it very often to help with scribing countertops to the back of walls, fitting filler strips, trimming cabinet ears, heck, even planing down the whole side of a cabinet that is just too big to fit in the desire space ;-P
Same goes if you’re a trim carpenter. Door sticking cause of the house settling? bust out the power plane. Trim needs to be adjusted down 1/16” to fit in between a door and another wall? bust out the power plane… you get the point now, I think.
-- Pete
View PPK's profile
PPK
#7 posted 12-11-2017 09:35 PM
- Texcaster
And I agree with the above too…
-- Pete
View sawdustdad's profile
sawdustdad
366 posts in 1086 days
#8 posted 12-11-2017 09:46 PM
I have a Bosch that I bought some 30 years ago. It’s incredibly useful when you need it. Freeing sticking doors is one of the best uses, but leveling rough slabs is another great use. I used it on a bench top, then followed with a hand plane to get to a final finish.
I would say it’s a specialized tool, but like they say, having the right tool for the job makes the work go much easier. For example, using a hand plane to remove 1/8 inch from a solid fir door would require some serious holding method to handle the forces you’d exert. No sweat with a power plane, hold the door on edge with one hand, and run the power plane along the edge with virtually no force applied to the door and you’re done a few seconds later.
-- Murphy's Carpentry Corollary #3: Half of all boards cut to a specific length will be too short.
View jdh122's profile
jdh122
1052 posts in 3019 days
#9 posted 12-11-2017 09:50 PM
I don’t have one, but watching Tips from a Shipwright on Youtube has persuaded me that it can be an accurate tool. Check out his description of modifications that he does to them when he buys them:
https://www.youtube.com/watch?v=Lx6uIODNeZI
-- Jeremy, in the Acadian forests
View CharlesA's profile
CharlesA
3351 posts in 1999 days
#10 posted 12-11-2017 10:04 PM
I bought one for a particular purpose, and it can be an awesome tool under the right circumstances. I have the Makita, and it is a very fine tool.
ChicagoHiker
#11 posted 12-12-2017 12:35 AM
Everyone – Thanks for all the advice. Sounds like it’s not going to meet my needs, but it’s good to know the pros and cons!
