Unknown Stanley Plane
Forum topic by danais posted 03-04-2011 09:27 PM 1285 views 0 times favorited 6 replies Add to Favorites Watch
View danais's profile
danais
4 posts in 2635 days
03-04-2011 09:27 PM
Can anyone tell what #plane this might be and what its value might be? I found it on CL and am not sure if I should consider buying it.
Thanks
D
View Bertha's profile
Bertha
13525 posts in 2688 days
#1 posted 03-04-2011 10:23 PM
It looks like a 220 maybe? Find out if it’s got an adjustable mouth; it looks like it might. Check the depth adjuster knob & see if it has deep circumferential etching. If it does, I think it might be an English 220; I think they call it the G220? It should be stamped into the side.
I’ve got the English 220 and to tell you the truth, I really like it. It’s certainly not what you’d call a “vintage” Stanley & the blade was modern and deeply machined when I got it. However, the casting is quite heavy & the mouth can be tightened very tight. I like mine and didn’t expect to. I don’t think it’s worth more than $30.00.
If it’s just a modern Stanley block plane, I don’t think it’s worth $10.00. It just doesn’t look very old to me, given the picture. Good luck!
View chrisstef's profile
chrisstef
17380 posts in 3001 days
#2 posted 03-04-2011 11:06 PM
It looks like a #60 1/2 or a #60 .. low angle block plane. Brand new they go for about $45. This one does look like a newer model … the older ones had a brass knob on the front. I just bought an older English version of the same plane for $20 but it was pretty well rusted and beat on.
Good luck!
View Loren's profile
10377 posts in 3643 days
#3 posted 03-04-2011 11:32 PM
Here:
http://www.amazon.com/Stanley-12-220-Block-Plane/dp/B00002X1Z8
Not the most useful block plane for furniture, but fine for a carpenter.
Not useless in the shop, just not capable of fine cuts.
I’d pay about $5-10 at a flee market if I needed it.
The 12-960 is a more useful all-round plane for the workshop because
of its adjustable mouth.
View bigike's profile
bigike
4052 posts in 3283 days
#4 posted 03-04-2011 11:50 PM
it sayes 12-220 on the pkg. in the left hand corner.
View poopiekat's profile
poopiekat
4354 posts in 3729 days
#5 posted 03-05-2011 02:10 AM
Well, what does the seller want for it?
View strippedscrew's profile
strippedscrew
2 posts in 2624 days
#6 posted 03-16-2011 08:49 AM
$15, tops. $5 to $10 is about right.
Not collectible.
-- sawdust
