Old Craftsman Router 315-25031
Forum topic by Dwain posted 12-10-2017 08:20 PM 298 views 0 times favorited 6 replies Add to Favorites Watch
View Dwain's profile
Dwain
501 posts in 3730 days
12-10-2017 08:20 PM
Topic tags/keywords: craftsman router vintage machinery collet power tool repair
Hey all,
I found an old Craftsman router, part number 315-25031 at my dad’s house when he passed. It starts like a top, but the collet doesn’t seem to tighten around my 1/4 inch shank router bits. I would very much like to get this working in my stable of routers, but being as old as it is, I’m not sure who can look at it, much less get parts for it in the Phoenix, Arizona area.
Anyone out Phoenix way have any contacts?
Much appreciated!
-- When you earnestly believe you can compensate for a lack of skill by doubling your efforts, there is no end to what you CAN'T do
View ohtimberwolf's profile
ohtimberwolf
736 posts in 2223 days
#1 posted 12-10-2017 09:52 PM
This might help as I know nothing else to say. larry
http://vintagemachinery.org/files/PDF/Craftsman/1963-315-25031.pdf
-- Just a barn cat, now gone to cat heaven.
View Lazyman's profile
Lazyman
1559 posts in 1258 days
#2 posted 12-11-2017 03:28 PM
Did you find any old router bits at your dad’s house? Just wondering if they fit any differently than your modern bits.
According to Sears Parts direct, there is no substitute part for the collet or nut. Your only option may be to find someone on eBay selling off parts. Even then there is no guarantee it won’t have the same problem.
Dwain
#3 posted 12-11-2017 05:43 PM
Lazyman,
I did. There were a few in the box with the router, some unopened! Those were the ones I was trying. Alas, no luck. I will try some of my current 1/4” shank bits and see what I can do.
Thanks for the idea!
View LesB's profile
LesB
1442 posts in 3313 days
#4 posted 12-11-2017 11:38 PM
I have two Craftsman routers of that same vintage if not slightly older. They work great. I have replaced the bearings in one but they are standard size bearings available in most places bearings are sold. The collet is 1/4”.
They don’t have a lot of power to drive large cutter heads but otherwise they work fine. I also have three larger Porter Cable routers.
-- Les B, Oregon
View MrUnix's profile
MrUnix
6188 posts in 2069 days
#5 posted 12-12-2017 12:06 AM
I got a similar one as well.. beat to hell and ratty looking as it gets, but the thing is a workhorse and it just refuses to die. The collet nut does require a bit of grunt to get it to grab properly, but it’s not excessive. Is it not grabbing at all or are the bits just slipping once tightened. A good cleaning and some sandpaper on the inside to roughen it up a bit usually helps.
Dwain
#6 posted 12-12-2017 05:46 AM
Hey,
I went back tonight and tried to do a few things. I sanded the shank on the bit and applied a little more pressure when cinching down the collet nuts. Seems to have worked! I’ll test a little more to make sure the bit isn’t slipping during use. Thanks for all the ideas!
