ultra band saw sled
Forum topic by skidiot posted 12-10-2017 12:56 AM 1027 views 0 times favorited 6 replies Add to Favorites Watch
View skidiot's profile
skidiot
83 posts in 3759 days
12-10-2017 12:56 AM
Topic tags/keywords: jig
Hi all,
Over the Thanksgiving weekend I scored a super nice Rikon band saw on Craigslist. I wanted it because of the 13” resaw height. I am resawing a white oak tree into quartersawn lumber for the clocks and lamps and other small things I make. I saw this sled on YouTube and thought the use of a clamp to be far better than screws. But, I thought I could take it up a notch. The one online had holes bored in the sides to reposition the clamp. I went with metal rails (Unistrut). This way all I have to do is loosen the eyebolts and slide the clamp wherever I want. Also, because I am quarter sawing, I have to hold the log at angles to get the best figuring. This way I can hold the log however i want.
Skidiot
-- skidiot northern illinois
View msinc's profile
msinc
497 posts in 618 days
#1 posted 12-10-2017 03:32 AM
I like it…in fact, I need that very thing!!! I don’t do a lot of resaw work, but when I do I need a sled. I typically cut burls for game calls and knife handle slabs…this is just the thing. Thanks a million for posting!!!
View AZWoody's profile
AZWoody
1396 posts in 1338 days
#2 posted 12-10-2017 04:23 AM
I’m going to be making a sled for cutting short log piece into turning blanks. I like what you did.
What are you using as a guide to feed the sled straight?
is it registering off the back of the table?
Does the youtube link have all that info?
skidiot
#3 posted 12-10-2017 05:34 AM
This saw has a slot on either side of the blade. There is a runner on the under side of the sled that fits into the slot.
View Kelly's profile
Kelly
2072 posts in 3059 days
#4 posted 12-27-2017 07:53 PM
You can also use your fence and a variation of yours. Just swap the bar clamp I used on mine for a pipe clamp:
http://lumberjocks.com/projects/197690
View Blackie_'s profile
Blackie_
4883 posts in 2627 days
#5 posted 12-27-2017 11:05 PM
Do you have a miter slot between the blade and the uprise? Just curious as to how you’re guiding that sled without getting off course?
My 14” Griz with a riser kit only has the one miter slot in from of the blade in which I use to guide my sled.
I’m using the screw sled but my sled is not limited to the length of the log I can place on it, in which I see yours is, but I never go over 24” in length as my back most likely wouldn’t allow it :)
-- Randy - If I'm not on LJ's then I'm making Saw Dust. Please feel free to visit my store location at http://www.facebook.com/randy.blackstock.custom.wood.designs
View BandsawJeff's profile
BandsawJeff
52 posts in 315 days
#6 posted 12-29-2017 07:31 PM
Cool Sled!
I bought a Little Ripper which is similar to what you have there. Worth checking out if you ever need to do longer stuff.
https://www.youtube.com/watch?v=4k-r5utmU2Q&t=233s
