No-Jig Pocket Holes
Forum topic by BorkBob posted 03-04-2011 03:54 PM 24363 views 1 time favorited 8 replies Add to Favorites Watch
View BorkBob's profile
BorkBob
127 posts in 2720 days
03-04-2011 03:54 PM
I’ve been using this technique for years using standard drill bits and short drywall screws. It recently occured to me that a longer bit would allow more angle and depth to the holes. I got some 6” aircraft bits and #6×1-5/8” trim head screws.
This is a vanity drawer base face frame for my own use. Wood is ash.
I start with the bit vertical about 1-1.25” from the joint and quickly bring it toward the horizontal, aiming for the center of the stile.
I follow a 1/8” bit with a 5/32” bit to increase the size of the hole in the rail. I drill about 1/2” deep.
Thank goodness for impact drivers:
Backside:
Front:
-- Please Pray for Our Troops / Semper Fi / Bob Ross / www.theborkstore.com
8 replies so far
View richgreer's profile
richgreer
4541 posts in 3102 days
#1 posted 03-04-2011 04:06 PM
Do you do this with hardwood also?
View Sawkerf's profile
Sawkerf
1730 posts in 3096 days
#2 posted 03-04-2011 04:35 PM
Your technique may be what led to the development of pocket hole jigs, but I suspect that it could lead to some problems if not done flawlessly every time.
I don’t think that I would use trim head screws, however. I use the Kreg system and the truss head screws give a lot of clamping force in the flat bottomed screw holes. Probably much more than trim heads would give. I set my drill clutch to ~10 – 12, drill speed to 1, and drive to the first “click” to get rock solid joints.
Good idea getting away from drywall screws. They’re way too easy to break.
View Bill White's profile
Bill White
4950 posts in 3988 days
#3 posted 03-04-2011 05:25 PM
Rich?? Ash?? Hardwood???
Bill
-- bill@magraphics.us
BorkBob
#4 posted 03-04-2011 06:02 PM
Gosh, I got the impression that everybody here does everything flawlessly every time….lol. It takes a bit of practice but with everything solidly clamped, it’s just a matter of drilling carefully.
Sawkerf, your concern is noted. If I weren’t confident the joints are plenty strong, I would not have posted here and risked the wrath of the collective wisdom.
I’m not saying the Kreg system is lacking. This is, IMO, a viable alternative.
View Raspar's profile
Raspar
246 posts in 3176 days
#5 posted 03-04-2011 06:31 PM
First, I give you props for doing this without the guide. But with a price point of the Kregs line you can not beat it. It works flawlessly and I do not have to think about it.
-- Have thy tools ready. God will find thee work.
10476 posts in 3675 days
#6 posted 03-04-2011 08:45 PM
For years I’ve drilled holes for pocket screws on the fly using a 3/8”
spade bit. I drill in perpendicular to the work for about 1/4” then
abruptly turn the drill to the angle I want. Works great, really.
Not suitable for cabinetmaking really, but for screwing together
2×4s and in a pinch on installations the results are very acceptable.
View bobsmyuncle's profile
bobsmyuncle
110 posts in 2718 days
#7 posted 03-06-2011 05:44 AM
I agree with this. For less than the price of a couple of those clamps, you’ve got all you need.
http://www.rockler.com/product.cfm?page=5985&filter=kreg
View woody57's profile
woody57
650 posts in 3455 days
#8 posted 03-06-2011 09:18 PM
I have drilled pocket holes this way, but I wouldn’t give up my kreg jig. For me the jig is a lot faster and you get acurate, consistant holes every time. If you are not consistant with the dept every time, the screws may puncture throught the material.
-- Emmett, from Georgia
