capacitor testing
Forum topic by Karda posted 12-09-2017 04:48 AM 516 views 0 times favorited 12 replies Add to Favorites Watch
View Karda's profile
Karda
1382 posts in 790 days
12-09-2017 04:48 AM
need some tips, I want to test the capacitor on my wood lathe, there are a million videos on utube giving instructions on how to do so but they all use capacitors with bayonet type terminals mine has wires and the wires are not marked or colored. also how to you connect the point of the test terminal with the capacitor wire. Thanks mike
12 replies so far
View TheFridge's profile
TheFridge
10816 posts in 1723 days
#1 posted 12-09-2017 04:58 AM
Twist wire around probes. AC caps aren’t polarized like DC.
MrUnix
7106 posts in 2436 days
#2 posted 12-09-2017 05:04 AM
Yup… doesn’t matter if it has spade terminals or not. Hold them on the stripped back wires with your fingers if you need to. Put probes on each wire, watch meter. Reverse probes, watch meter. About as simple as it gets.
View Marshall1's profile
Marshall1
8 posts in 780 days
#3 posted 12-09-2017 01:32 PM
Disconnect from machine, discharge capacitor by connecting terminals to each other with insulated tool or another piece of wire. (This is a shock hazard) Check microfarad reading with multimeter compared to what is printed on outside of capacitor.
Karda
#4 posted 12-09-2017 04:53 PM
ok
View hairy's profile
hairy
2783 posts in 3769 days
#5 posted 12-09-2017 04:53 PM
Take it to an auto parts store, or a repair shop. They will probably check it for little or no money. It’s a 1 or 2 minute job for someone that knows how.
Take some doughnuts with you.
-- My reality check bounced...
Karda
#6 posted 12-09-2017 04:55 PM
thanks never thought of that
View Carloz's profile
Carloz
1147 posts in 828 days
#7 posted 12-09-2017 05:11 PM
Buy yourself a pair of crocodiles. Very handy for all electrical work.
Karda
#8 posted 12-09-2017 05:58 PM
yea if I can find them, no radio shacks around here any more, not sure if they would work, the terminals on my tester are just a short point. Ill just have to fiddle thanks Mike
View Woodknack's profile
Woodknack
12464 posts in 2617 days
#9 posted 12-09-2017 06:32 PM
I thought you already replaced the capacitor.
Karda
#10 posted 12-09-2017 06:39 PM
I replaced the capacacitor but there was no change the lathe still turns slow, I want to test to rule out the capacitor and verify the new one is working. I don’t think it is the capacitor because only the 2 highest speed don’t work
hairy
#11 posted 12-09-2017 07:40 PM
That only has 1 capacitor? If so, it’s good if the motor starts. It gives a boost on startup. there are start and run capacitors.
Karda
#12 posted 12-09-2017 10:08 PM
ok thanks
