| Forum topic by damnHippie | posted 168 days ago | 236 views | 0 times favorited | 11 replies | ![]() |
168 days ago |
Topic tags/keywords: question joining dovetail So I’m stuck. Actually, my dovetails are stuck. I tried a “dry fit” after a little paring, and used a dead blow to get the pieces together. Now, I can’t seem to get them apart. Any recommendations? I don’t want to splinter the wood. You can see here one of the pins is beginning to complain from my manual attempts to pull the pieces apart…
-- 10 fingers, 2 eyes, and healthy lungs. for now. :P |
168 days ago |
Well the joint looks nice and tight – it actually looks super! Why don’t you throw it in the dryer! Or the toaster. See if it’ll shrink the wood. HA. Can you try sticking the tail side in a vice – or flat on the bench – and then, with a thin block of wood and mallet, tap the pins lightly, alternating pins to avoid jamming the pin board. If that doesn’t work – better head to the toater oven… No glue needed for that particular joint! -- Dorje (pronounced "door-jay"), Seattle, WA |
168 days ago |
Or the microwave or put it in front of an electric space heater. I have used the space heater thing to shrink wood before. It really works. -- Gary, East TX -- The longest journey begins with a single step. |
168 days ago |
Why take them apart? They obviously don’t need glue. If you have to hit them with a dead blow mallet to get them together they will absolutely bee to tight once the glue is applied. They should slide easily together “just right” when dry because the glue will cause swelling. Awesome job on the dovetails though. If you do get them apart pare a little more away before gluing. -- Dust collectors suck. |
168 days ago |
I use a piece of wood and a hammer. -- Thos. Angle, Owyhee Design, Oregon |
168 days ago |
My 2 cents- I usually cut my dovetails then check to see if they look like they will fit together without driving the joint all the way together. Dovetail joints should be nice and tight and when you dry fit them you’re loosening the joint. Eye ball the joint, puts some glue on it, and put it together once. -- Tim -- http://tmuli.com |
168 days ago |
One day, I’ll be able to do what tenontim suggests. One day. -- Eric at http://adventuresinwoodworking.com |
168 days ago |
I do the same as Thomas a piece of wood so not to damage/bruse the wood, a hammer and tap it out. |
168 days ago |
I agree with Thomas too; use a piece of wood and hammer to work them apart…SLOWLY. If you have access to a woodstove it will shrink the wood and make separation easier (just like Gary recommended). Woodstoves suck the mositure out of all wood so toss is near by and give it hours/days by the woodstove. As a general rule I was always taught to not fully dry fit my dovetails for this very reason. Nonetheless, just spend some work tapping them apart…pick a low humidity day and you’ll be good. |
167 days ago |
damnHippie, This happens to me all the time. What I do is put a side of the piece in the vise and jiggle the other side carefully. The jiggling will slowly make the joint come apart. Alin -- -- Alin Dobra, Gainesville, Florida |
167 days ago |
If you pull these dovetails apart, they will not fit as well when you put them back the second time. A dovetail is the strongest joint known to woodworkers. If you are making a drawer, just go ahead I build the drawer without glueing them together. Trust me, they will never come apart. If you try to hit it with a hammer and block of wood, something is going to give (and it wont be the hammer or block of wood) I have built drawers before without glueing my dovetails and 4 years later they look just as nice. When you put the bottom of the drawer in, this will keep the entire assembly stable. Trust me, it works. Jeff -- Jeff, Indiana |
167 days ago |
So I got the pieces apart, using the clamp + block of wood + hammer formula. My plan was, if tapping it didn’t work, then I’d add dry heat and try again. It all came apart ok, no splinters or breaks in the primary wood. (Phwew!) Thanks everybody for the recommedations. I figured it was going to turn out to be somethng like what y’all said, I just got scared and stewed over it for a day. Thanks again! -- 10 fingers, 2 eyes, and healthy lungs. for now. :P |
| Sponsor | Forum | Topics |
Woodworking Skill Share
1104 |
1482 |
103 |
283 |
95 |
Woodworking Trade & Swap
197 |
Coffee Lounge
795 |
LumberJocks.com Site Feedback
251 |
