Quartersawn lumber
Forum topic by jerkylips posted 12-08-2017 05:34 PM 1612 views 1 time favorited 33 replies Add to Favorites Watch
View jerkylips's profile
jerkylips
483 posts in 2807 days
12-08-2017 05:34 PM
It seems like any time I see references to quarter sawn lumber, it’s oak. I’ve never seen any “quarter sawn maple” projects. Is there a reason that other species aren’t cut this way? Just curious..
33 replies so far
View gargey's profile
gargey
1013 posts in 1012 days
#1 posted 12-08-2017 05:55 PM
If you quartersaw maple the angle of the cuts releases demons that are stored in the wood cells, its not safe.
Obviously, oak doesn’t have any demons in it.
Also, quartersawn (white) oak reveals prominent ray flecks that provide a lot of visual interest, so oak is often cut and advertised that way.
Any wood can be quartersawn – it provides a different look (more uniform vs cathedral grain), and also different wood movement properties that are usually preferred. It is more difficult and more costly.
View Rich's profile (online now)
Rich
4000 posts in 826 days
#2 posted 12-08-2017 05:56 PM
I have quarter sawn cherry, sapele and wenge out in the shop. White oak is the classic though. It’s what pops into most people’s head when they hear quarter sawn.
Rich
#3 posted 12-08-2017 05:58 PM
- gargey
What about my cherry, etc? Are there demons, or is it just maple? Maybe I should play it safe and burn it.
View Frederick Desroches's profile
Frederick Desroches
22 posts in 407 days
#4 posted 12-08-2017 05:58 PM
Sapele, zebrawood ant other are often quater sawn. To show a distinctive pattern.
Oak when quatersawn show some desired figures, i think thats why
I think that quater sawn not common even if more stable because it results in a lot of loose.
-- Fred, Canada
View AlaskaGuy's profile
AlaskaGuy
4989 posts in 2546 days
#5 posted 12-08-2017 06:05 PM
A quick search reveals there are plenty of place to buy 1/4 sawn maple. One place even says it a favorite of instrument makers.
http://www.bellforestproducts.com/quarter-sawn-maple/
View MrFid's profile
MrFid
888 posts in 2141 days
#6 posted 12-08-2017 06:08 PM
Quartersawn white oak (any oak, but especially white) looks very different when QS as opposed to flatsawn or riftsawn. It is desirable for that quality. Most woods don’t look very drastically different when QS. There is some different grain patterning associated with the different cuts, but in general it takes a bit of a trained eye to tell (which many of us around here have, but few others).
The biggest reason to quartersaw lumber is because it adds a lot of stability to the wood. The lumber will expand and contract mostly along its width, rather than its length. This is helpful in lots of applications. However, if a species is very stable to begin with, then quartersawing doesn’t add as much value to the wood. And it matters because when you saw a log into lumber, the most efficient way to saw doesn’t yield much QS lumber. Example: A log might be able to yield 8 boards of QS lumber, or 14 boards, some of which are QS, some flatsawn, and some riftsawn. If you can sell 14 boards rather than 8 with the same log, most people will do that.
-- Bailey F - Eastern Mass.
jerkylips
#7 posted 12-08-2017 06:44 PM
Obviously, oak doesn t have any demons in it.
Ahh….maple demons. Makes sense.. The ghost of Aunt Jemima, maybe?
Rich
#8 posted 12-08-2017 07:02 PM
- jerkylips
I think Aunt Jemima would only be involved if there was a wood species called high fructose corn syrup :)
View bondogaposis's profile
bondogaposis
5150 posts in 2588 days
#9 posted 12-08-2017 07:27 PM
Sycamore has the best figure when quarter sawn.
-- Bondo Gaposis
View ArtMann's profile
ArtMann
1216 posts in 1053 days
#10 posted 12-08-2017 08:18 PM
I persuaded my sawyer to cut and dry some quarter sawn Sycamore for boxes and other small items and it is truly beautiful. He had a hard time with it and said he wouldn’t be doing that again. I don’t know why. Quarter sawn Cherry can have a similar pattern to Sycamore but not always.
View avsmusic1's profile
avsmusic1
300 posts in 922 days
#11 posted 12-08-2017 08:28 PM
- Rich
Burning it just angers them. Better play it safe and just send it my way
View jdh122's profile
jdh122
1058 posts in 3054 days
#12 posted 12-08-2017 08:28 PM
QS beech has nice figure too, looks different from flawsawn.
-- Jeremy, in the Acadian forests
jerkylips
#13 posted 12-08-2017 10:52 PM
- jerkylips
You make a valid point…
- Rich
View fuigb's profile
fuigb
541 posts in 3194 days
#14 posted 12-08-2017 11:03 PM
When I’m making my own I almost always quartersaw for the sake of stability. Dunno for certain if it helps but it certainly helps to give some wood a nice pop. Maple, sycamore, and cherry have all come out well. When I tried with apple I ruined a blade but that was my fault.
-- - Crud. Go tell your mother that I need a Band-aid.
View Tony_S's profile
Tony_S
953 posts in 3320 days
#15 posted 12-08-2017 11:35 PM
Any Quarter Sawn lumber(called vertical grain in softwoods) will be far more stable than Flat Sawn, due to the growth rings being perpendicular to the face of the board vs. semi parallel to the face. One drawback is quarter sawn lumber can have a lot more bow than flat sawn. Usually not a problem except for longer lengths(more waste).
The reasons for quarter sawn lumber not being readily available in most species is a combination of a couple of simple factors.
More time and waste when sawing a log which raises the end cost.
and truthfully….’most’ Q sawn lumber is boring to look at comparatively speaking vs. a flat sawn cathedral grain.
People don’t want to pay more…for less.
It has it’s place though, especially in modern, and some contemporary Architectural mill work.
-- It is the mark of an educated mind to be able to entertain a thought without accepting it. Aristotle
showing 1 through 15 of 33 replies
