Which ~6000grit waterstone?
« back to Hand Tools forum
Forum topic by amateur77 posted 12-08-2017 12:41 AM 694 views 0 times favorited 17 replies Add to Favorites Watch
View amateur77's profile
amateur77
14 posts in 211 days
12-08-2017 12:41 AM
I currently got a 400/1000 diamond stone, does a nice job, however now need something finer around 6000 probably before I attack it with a strop and super fine paste.
Have no idea whatsoever about all the brands for the non-diamond stones, so looking for some feedback.
I currently have my eye on the King KDS 1000/6000 Combination £37.88 from amazon, (that’s what one video suggested) , also supposedly it’s a better stone than the standard king combi.
https://www.amazon.co.uk/King-1000-Combination-Whetstone-Medium/dp/B0034YR016/ref=sr_1_cc_1?s=aps&ie=UTF8&qid=1512689819&sr=1-1-catcorr&keywords=king+kds
Is there anything better for around the same price or a little bit more/less ? Need something that is wide as I sharpen with a guide and my largest plane blade is 6cm wide, something the width of the king kds at 6.6cm would be spot on!
17 replies so far
View NeophyteGrant's profile
NeophyteGrant
29 posts in 418 days
#1 posted 12-08-2017 02:42 AM
I’m just getting in the sharpening game, so I can’t say from use or experience—so caveat there—but having just been in the hunt for waterstones, I wasn’t impressed by King (at least what I saw on Amazon). Another thing that seems to be worth noting is that the Kings in the lower price range at least are all about 2 inches wide—good for chisels but problematic for some wider things like plane soles. Norton seems to be a good mid-level option (also available on Amazon if you’re an Amazon junkie like me). I went in for a 4k of theirs.
Lie Nielsen attests to these stones: https://www.lie-nielsen.com/product/blade-sharpening/blade-sharpening-ohishi-waterstones-?node=4203
I bought one but haven’t used it.
NeophyteGrant
#2 posted 12-08-2017 02:42 AM
...and many of the Nortons are 3 inches, comparatively.
View Andre's profile
Andre
1669 posts in 1715 days
#3 posted 12-08-2017 02:57 AM
My 1st water stones were the Norton 1000/8000 combo, still have them (50% left) and use them as the 8000 is a little harder than most so dose not gouge as easy. I find the high end stones tend to be quite soft so caution and experience required so as to not damage them. Yes the Lie- nielsen stones are worth the money!
I have never used a water stone on a plane sole? 220 grit sandpaper is as far as I go, use body shop self adhiviseve rolled sandpaper and just stick it onto a cast jointer table.
View bbasiaga's profile
bbasiaga
1124 posts in 1904 days
#4 posted 12-08-2017 01:48 PM
I have a Norton 4k/8k combo. It is 3” wide, or about 7.5cm. Seems like it might be a good fit for you. I am not sure what the price would be on your side of the pond.
Brian
View AUswimKC's profile
AUswimKC
36 posts in 1857 days
#5 posted 12-08-2017 02:06 PM
Sigma 6k from toolsfromjapan
View UpstateNYdude's profile
UpstateNYdude
912 posts in 1892 days
#6 posted 12-08-2017 02:06 PM
Buy the Japanese version of the Shapton Pro 5000 stone, way cheaper and it’s the exact same stone as the US version only WAY cheaper.
-- Nick, “I am always doing what I cannot do yet, in order to learn how to do it.” – Vincent Van Gogh
View Gene Howe's profile
Gene Howe
10136 posts in 3337 days
#7 posted 12-08-2017 02:10 PM
Buy the Japanese version of the Shapton Pro 5000 stone, way cheaper and it s the exact same stone as the US version only WAY cheaper.
- UpstateNYdude
Can you post a source? I’m interested.
View JRsgarage's profile
JRsgarage
236 posts in 418 days
#8 posted 12-08-2017 02:30 PM
i’ve been using a s5000 Naniwa super stone and it does a decent job. easy and convenient but downside is that it’s permanently attached to the cheap base
-- Two is One, One is None
View Mr_Pink's profile
Mr_Pink
45 posts in 280 days
#9 posted 12-08-2017 02:41 PM
I have a King two-sided waterstone that’s wide enough for jointer plane blades. I’m sure there are better stones out there, but the stone I have was relatively cheap and never fails to sharpen a blade.
View Tim's profile
Tim
3734 posts in 1870 days
#10 posted 12-08-2017 04:59 PM
I got the Ohishi 3000/8000 from Lie-Nielsen because it doesn’t have to be soaked and that combination of grits appealed to me to use after a 1200 grit diamond stone. I can’t say how it compares to any other water stones but I like it. At 8”x3”. it’s a good size too.
View jerkylips's profile
jerkylips
362 posts in 2479 days
#11 posted 12-08-2017 05:15 PM
not sure if it helps, but I’ve found some stuff on this site -
https://www.japanwoodworker.com/categories/sharpening-stones
View retfr8flyr's profile
retfr8flyr
381 posts in 1578 days
#12 posted 12-08-2017 10:11 PM
Another fan of the Sigma stones from http://www.toolsfromjapan.com/store/index.php?main_page=index&cPath=335_404_403 Great guy to work with and quality products.
-- Earl
AUswimKC
#13 posted 12-08-2017 11:22 PM
Skip the Shapton 5k. Has a weird feel and cuts slowly
I run with a Shapton Pro 1k. Sigma 6k. And a Shapton 12k. Some like an 8k.
ToolsForJapan used to have an awesome set. Probably still do. Three stones and a flattening stone.
View Sawdust35's profile
Sawdust35
30 posts in 771 days
#14 posted 12-09-2017 02:39 AM
OP, I started my hand sharpening with that King combo stone. I have moved onto Shapton waterstones 1k, 5k and 8k. The shaptons require less flattening and less water when sharpening (no presoaking). If I were to start from scratch, I’d go with the shapton or the sigma stones.
View LazarusDB's profile
LazarusDB
13 posts in 74 days
#15 posted 12-12-2017 07:53 PM
I have been using King stones up to 8000 and felt it did an ok job but felt they should still be sharper. After going to a local Lie-Nielsen hand tool event a couple weeks ago I bought a 1000 and 10k Ohishi waterstones. My little block plane has never been so sharp. And like Tim said, they don’t need to be soaked.
-- Aaron - Aspiring Craftsman
