| Forum topic by thughes37 | posted 813 days ago | 994 views | 0 times favorited | 7 replies | ![]() |
813 days ago |
I’m primarily a woodturner and I am looking to add a buffing system to my arsenal of tools. I found that the Beall Buffing System has an adapter that works with a #2 MT for lathes so that you don’t have to find a seperate 1/3HP or greater motor. Has anyone used this system this way and if so, is it something to consider? If not, where would anyone recommend finding an “inexpensive” 1725RPM motor to use? Appreciate all ideas and comments. Thanks. -- All things are possible, only believe. |
7 replies so far
#1 posted 813 days ago |
I use the Beall system with the adapter and love it. I just pop in my lathe, older delta midi lathe, and change out the wheels. It is easy to change and I really like the amount of space (lack of space) it takes up in my shop. My brother has the sysytem with all three wheels connected. I notice there is not a lot room between wheels and you tend to hit the other wheels with your project. -- Greg, Concordia, Mo "All the horns of the wicked I will cut off" Psalm 75:10 |
#2 posted 813 days ago |
I also use the Beall system on my lathe. I don’t bother with a Morse Taper connection. I simple grab the piece that holds the wheels with my chuck. Works great. I also agree with Greg that people who put all 3 wheels on their lathe at one time don’t have enough room between the wheels. It only takes a few seconds to change wheels. -- Rich, Cedar Rapids, IA - I'm a woodworker. I don't create beauty, I reveal it. |
#3 posted 813 days ago |
Rich, do you use smaller jaws? -- All things are possible, only believe. |
#4 posted 813 days ago |
I love mine. I do use it with the morse taper, and I do use all three wheels at once. Since I have a small lathe and turn relatively small pieces, it works great that way for me. I can see, though, why one might want to use one wheel at a time with larger turnings. -- Charlie M. "Woodworking - patience = firewood" |
#5 posted 813 days ago |
I use the standard jaws that came with my One Way Talon. -- Rich, Cedar Rapids, IA - I'm a woodworker. I don't create beauty, I reveal it. |
#6 posted 813 days ago |
Extra motors can be scavanged from a washer or dryer. Don’t know the rpm, does anyone else? -- Backer boards, stop blocks, build oversized, and never buy a hand plane-- |
#7 posted 812 days ago |
Most regular electric motors run at 3450 rpm. That’s too fast for buffing, but you can gear them down. IMO buffing should be done around 1200 rpm. -- Rich, Cedar Rapids, IA - I'm a woodworker. I don't create beauty, I reveal it. |
| Forum | Topics |
Woodworking Skill Share
8798 |
Woodturning
224 |
Woodcarving
28 |
Scrollsawing
61 |
Joinery
82 |
Finishing
1537 |
3554 |
15806 |
Hand Tools
2039 |
Jigs & Fixtures
496 |
Wood & Lumber
2846 |
810 |
Focus on the Workspace
903 |
766 |
Woodworking Trade & Swap
2741 |
LumberJocks.com Site Feedback
1547 |
Coffee Lounge
6165 |
