Help!! I've ruined my boyfriend's coffee table with nail polish remover and need advice!
Forum topic by Ashley19448 posted 12-07-2017 08:22 PM 1774 views 0 times favorited 12 replies Add to Favorites Watch
View Ashley19448's profile
Ashley19448
1 post in 349 days
12-07-2017 08:22 PM
Topic tags/keywords: table repair
Yesterday, like an idiot, I was using nail polish remover on the coffee table. It of course leaked through onto the table and leaving a sizable mark on the table. He tried to play it cool, but I know he was mad as I would be as well. Any advice how on how to repair it before I replace it would be greatly appreciated. It’s a mass produced piece of furniture, so I don’t think it’s stained. The color came up too quickly/easily.
12 replies so far
View Markespen's profile
Markespen
8 posts in 651 days
#1 posted 12-07-2017 10:04 PM
First the good news: the finish is probably lacquer. Newly applied lacquer will melt in with the existing finish without creating a ridge. Now the bad news. Instead of using a traditional staining process (wood is stained and THEN covered with a clear lacquer), production furniture makers use a toner. A toner is a mixture of lacquer and stain/dye that is sprayed onto the piece in a single step. They can get a lot more color onto the wood doing this. Your nail polish remover has removed the toner exposing bare wood.
The end result is that you’re going to have to match the color (either stain or dye). In my opinion, the best way to do this is to try stains until you get the right color. You’ll want to test it on the underside first. You’ll then need to mix some brushing lacquer, lacquer thinner and stain. The best is to apply thin coats with an airbrush. Harbor Freight has some cheap ones that work for this but you’ll need a compressor.
If you can’t match the color, you might get a decent repair by brushing on some thinned lacquer onto the damaged area and trying to feather in some of the color from the area surrounding the spot. Again, try on the underside first if you can.
Regardless, wipe down first with mineral spirits to remove any wax and cross your fingers that Endust or Pledge haven’t been used on the table.
I’ve been pretty successful with these methods but I’m sure there are more experienced finishers on here that can add to or correct any of my recommendations. Good luck.
-- Mark - Owasso, OK
View Mike_in_STL's profile
Mike_in_STL
709 posts in 712 days
#2 posted 12-08-2017 01:07 AM
Or, you could do like my wife does and strip and sand the whole thing to bare wood and refinish in a completely different color. Otherwise, Mark is right.
-- Sawdust makes me whole --Mike in STL
runswithscissors
2875 posts in 2203 days
#3 posted 12-08-2017 01:11 AM
“The Furniture Doctor” by George Grotz has a ton of info on problems of this kind. Plus, it’s an enjoyable, entertaining read. Surprising, given the topic.
View sawdustdad's profile
sawdustdad
366 posts in 1063 days
#4 posted 12-08-2017 01:12 AM
OK, here’s the easy way to do it. Go to a Home Depot or Lowes and buy a furniture touch up set of markers. Basically a set of magic markers in different browns to match furniture colors. Then, pull out a bottle of clear nail polish.
Using the markers, color the wood to close to what is was originally. Then, touch up the area with some clear nail polish. You may want to apply it with a rag rather than a brush so it spreads out in very thin layers rather than a single thick layer. Apply a couple layers.
Put a magazine over the repair and turn the table around so the damage is in a different location than before.
-- Murphy's Carpentry Corollary #3: Half of all boards cut to a specific length will be too short.
View Carloz's profile
Carloz
1147 posts in 770 days
#5 posted 12-08-2017 01:14 AM
- MikeinSTL
She is not a wife yet, so she does not have to sand . Girfriends have their ways to deal with these things.
Mike_in_STL
#6 posted 12-08-2017 01:24 AM
^^^Don’t we all know about that?^^^
View jonah's profile
jonah
1880 posts in 3477 days
#7 posted 12-08-2017 02:17 AM
OK, here s the easy way to do it. Go to a Home Depot or Lowes and buy a furniture touch up set of markers. Basically a set of magic markers in different browns to match furniture colors. Then, pull out a bottle of clear nail polish.
- sawdustdad
I’d try this before I messed around with mixing new lacquer + colors. The repair marker things are actually not bad. If you have any artistic talent at all, you can even try to match the wood grain with a darker color after filling in the lighter color. You can also do that with a pencil. You can then either use clear nail polish or a bit of lacquer to put the clear coat back on.
View Firewood's profile
Firewood
488 posts in 1812 days
#8 posted 12-08-2017 04:18 AM
I haven’t personally used it, but I’ve seen a product from Touch Up Solutions for this type of repair. It is a tinted aerosol that comes in about a dozen different colors. I can’t say for certain if it is lacquer based or not. It is available at Woodcraft. Hope you find a good fix.
-- Mike - Waukesha, WI
View CWWoodworking's profile
CWWoodworking
184 posts in 357 days
#9 posted 12-14-2017 02:31 AM
Touch up solutions used to make a powder that you kind of rub in the color then needs to be sealed. The advantage to this method is that it is controlled better. using markers and such, you always seems to get color on the surrounding area that wasn’t damaged. Same with a toner.
-Clint
View Andre's profile
Andre
2145 posts in 1984 days
#10 posted 12-14-2017 04:17 AM
I think you need to go buy him a new Sawstop Table Saw and if possible some wood so he can make a new table!
View richardchaos's profile
richardchaos
583 posts in 558 days
#11 posted 12-14-2017 12:09 PM
Buy him a new table saw. He will never even mention the table
-- “In a time of universal deceit, telling the truth is a revolutionary act.” ― George Orwell
View Blake Haskins 's profile
Blake Haskins
229 posts in 1416 days
#12 posted 12-14-2017 12:57 PM
spill nail polish remover on the rest of it
-- make sure you subscribe to my channel- https://www.youtube.com/channel/UCRuWi7P7eIcNOckoxBI-ZRA
