Signing your work
Forum topic by Jack Labor posted 03-03-2011 03:41 PM 1813 views 3 times favorited 7 replies Add to Favorites Watch
View Jack Labor's profile
Jack Labor
52 posts in 2637 days
03-03-2011 03:41 PM
Topic tags/keywords: tip trick
I started signing my pieces from the start ( I prefer to sign them on the back, especially on smaller projects ) but I found that the ink would sometimes smear or run as I applied the final spray/brush on finish. Especially with open grain woods
I came up with an idea. I designed a logo on the computer and then made a mirrored (reverse) image of the logo. I then made several copies on a single sheet. I then made Xerox copies of the sheet.
(You can ‘resize’ the images to fit the piece.)
From there, I cut out one copy of the logo and positioned it ( face down ) on the Backing Board. Using masking tape, secure it along one end.
This should be done on sanded, raw wood. (before any finish is applied)
Using a small iron, set on ‘Cotton’(High Heat) I rub the hot iron over the back of the paper, being careful to press firmly and evenly being careful not to scorch the wood. When the paper is heated, the Xerox ink is “melted’ and transferred from the paper to the bare wood.
You can lift the end that is not taped to check the image to make sure all of the image is visible.
When cooled the logo will not smear or run when you apply your gel coat or spray-on finish.
I used this technique on the Victrola and Dog a number of years ago. After I transferred the ‘Victor’ and “Her Master’s Voice”, I went over the letters with a wood burning tool. Just to make sure it stood out just enough. But when you are transferring you signature or a small logo, the wood burner is not used.
Remember: XEROX not Inkjet or Laser Printer.
If you have any questions regarding this technique, please contact me at:
jlabor@elmwoodintarsia.com
-- Jack Labor - Elmwood Intarsia - Artistry In Wood
7 replies so far
View knotscott's profile
knotscott
8007 posts in 3370 days
#1 posted 03-03-2011 05:45 PM
That’s a clever method of signing your work. My method also uses ink, but I apply it with a rubber stamp that cost < $10. I clear coat over it to protect it. The size can’t be varied unless I were to use different size stamps, but it works well and looks a lot like a more expensive branding iron. I also like to add a penny from the year the piece was made.
The stamp looks something like this:
View David Craig's profile
David Craig
2137 posts in 3103 days
#2 posted 03-03-2011 06:25 PM
Clever idea. Using the Xerox would be about the same as using a laser printer though. The laser and Xerox both use toner which is what makes the ironing process work. Heat is used to transfer the toner on the paper and makes it usable to transfer to the wood using an iron. You are correct in stating you can’t use ink jet printers because they use liquid ink which is not heat transferable.
David
View CanadaJeff's profile
CanadaJeff
207 posts in 3604 days
#3 posted 03-03-2011 06:44 PM
You should post an example to see!
Sounds like a good idea, is it a clean transfer or do you get a faded version because not all the ink gets absorbed into the wood?
View rogerw's profile
rogerw
262 posts in 2684 days
#4 posted 03-04-2011 01:53 AM
cool idea. thanx for the post
-- >> my shop teacher used to say "do the best at everything you make for your mom because you're going to see it for the rest of your life!" <<
View Roper's profile
Roper
1389 posts in 3707 days
#5 posted 03-04-2011 02:12 AM
I just use my woodburning pen to put my signature on the bottom of my pieces,I only initial my minis.
-- Roper - Master of sawdust- www.roperwoodturning.com
View bigike's profile
bigike
4052 posts in 3283 days
#6 posted 03-04-2011 04:17 AM
nice idea, I like it cuz you can size the sign to fit the piece.
View redryder's profile
redryder
2393 posts in 3096 days
#7 posted 03-04-2011 09:27 AM
I like the “blog” by David….”Waterslide Decals”, easy and very professional looking. Remember when you were a kid and you put decals on your models?? same, same…....
-- mike...............
