Whch is the right finish?
Forum topic by NewfieDan posted 03-03-2011 03:32 PM 841 views 0 times favorited 2 replies Add to Favorites Watch
View NewfieDan's profile
NewfieDan
50 posts in 2677 days
03-03-2011 03:32 PM
Topic tags/keywords: question finishing
I am building a childs’ horseshoe set. Once it is completed I plan on using paint for the horseshoes themselves. The stakes are made from two pieces of 3/4 plywood laminated together. But for the stakes, that have to be driven into the ground, what type of finish should I put on?
My thoughts are that it should be some type of oil to prevent any moisture from the ground affecting the stakes. A hard surface film like poly would simply not last from repeated driving into the ground.
What are your thoughts on this?
2 replies so far
View richgreer's profile
richgreer
4541 posts in 3103 days
#1 posted 03-03-2011 04:15 PM
Are you using pressure treated plywood to make the stakes? If not, I would recommend using it. It will hold up to the weather better than anything you can do with regular plywood.
View Earlextech's profile
Earlextech
1162 posts in 2719 days
#2 posted 03-04-2011 04:14 PM
You should coat them with a product called No.10 Green wood preservative by Cuprinol. Absolutely use pressure treated lumber, then coat with No.10, then paint multiple coats of a good exterior grade latex paint.
