Issue rotating cutters on helical head - hint
Forum topic by rwe2156 posted 12-07-2017 04:00 PM 465 views 0 times favorited 5 replies Add to Favorites Watch
View rwe2156's profile
rwe2156
3174 posts in 1686 days
12-07-2017 04:00 PM
I just loosened and discovered several were too high because little dust got underneath.
Next time I will have the compressed air handy.
I just used the screwdriver they supplied but I wonder do any of you guys torque them down?
Its a Byrd head.
5 replies so far
View TheFridge's profile
TheFridge
10767 posts in 1692 days
#1 posted 12-07-2017 04:08 PM
I did the same on a couple. So I went through the head again with a brass wire brush and actually read the instructions this time before doing it.
Yes I got a 1/4 inlb torque wrench off of eBay and I believe Summerfi got one as well for his new planer.
View GR8HUNTER's profile
GR8HUNTER
5168 posts in 918 days
#2 posted 12-07-2017 04:10 PM
this is from their website :
If rotating, remove and clean the tip and seat, if replacing a broken tip check for any burs or embedded carbide flakes that must be removed install per drawing on the other side, torque to around 45 inlb ( a hard hand tightening) with a T25P Torx Plus Bit. A slight offset between tip’s countersunk hole and the screw is normal.
hope this helps you out rwe2156 :<))
5179 posts in 2699 days
#3 posted 12-07-2017 04:46 PM
I removed all mine and cleaned the seats before I even used them. Kinda tedious, but I thought it was necessary. I do torque them done per specs. Remember, these are carbide and they will crack if over tightened. I have one of those screwdriver type torque wrenches I used for scope rings on my rifles…it worked just fine.
View HorizontalMike's profile
HorizontalMike
7770 posts in 3120 days
#4 posted 12-07-2017 05:41 PM
Yes, I absolutely torque each and every one on my G0593 (at 50 inch pounds). The last thing I need is to break off a screw head from either over-torquing at the time of rotating cutters, OR having an over-torqued screw decide to break while in use.
One thing I did discover when rotating the cutters, is that cutters that have been used the longest tend to shorten the width of each cutter when rotated a quarter of a turn. Basically the 4-sided cutters are really only on two sides. After rotating on 90* I found a series of very very slight lines, similar to how nicks on regular jointer knives show. Just have to remember to lightly sand…
View pintodeluxe's profile
pintodeluxe
5798 posts in 3019 days
#5 posted 12-07-2017 05:53 PM
Firm hand tightening with the supplied screwdriver has worked for me. I agree, compressed air is a must.
