A question for the turners
Forum topic by armylogger posted 03-03-2011 04:34 AM 1069 views 0 times favorited 6 replies Add to Favorites Watch
View armylogger's profile
armylogger
41 posts in 2851 days
03-03-2011 04:34 AM
Topic tags/keywords: lathe turning
Ok, so I have been wanting to get a lathe for some time now. I got $250 worth of gift cards from woodcraft at christmas and have been saving them for this special occasion. I have looked around and finally decided on a Rikon. Now my biggest problem is whether I should get a variable speed or not. I want to turn all kinds of items. Small bowls, pens, lidded boxes, pepper mills, and many other items. I have talked to a few people who have told me that the variable speed lathes do not have enough torque to turn larger bowls. ( bigger than 6 inches). Is this true? I will be getting the rikon 1216 with a 1/2 hp motor. It comes either with or without variable speed and they are both the same price on sale at woodcraft for $299. I would really appreciate as much feed back as humanly possible as it will seriously help in my decision making. I will be posting this in the blog section also. Again, thank you all.
-- Of all the people I have met in my life, you are one of them!
View cabmaker's profile
cabmaker
1696 posts in 2715 days
#1 posted 03-03-2011 04:58 AM
As for your torque question, I do not know. What I can say is that I have vfd on mine and have turned some pretty hefty objects without failure. I have turned for several hours at a time on many occasions and I don t think I would want to be without the variable speed (electronic).
View richgreer's profile
richgreer
4541 posts in 2981 days
#2 posted 03-03-2011 05:39 AM
Electronic variable speed and the variable speed on the Rikon you are considering are quite different. I’m quite sure the variable speed on the Rikon is a mechanical system referred to as a “Reeves System”.
IMHO – The Reeves system is okay but you need to plan on changing belts frequently because the system is hard on belts. I would not pay a lot extra for a mechanical variable speed (Reeves System) but it is worth a little more. If they are both the same price, get the variable speed.
I do not agree that the variable speed system would reduce torque by any noticeable amount. Your bigger problem/limitation will be the 1/2 hp motor. That. more than anything else, will limit your ability to turn bigger bowls.
I own a 2 hp lathe but I have used other people’s 1 hp lathes. The difference is very noticeable. In my opinion, a 1/2 hp lathe will be disappointing on a bowl greater than 6 inches.
View GavinSA's profile
GavinSA
21 posts in 2549 days
#3 posted 03-03-2011 08:13 AM
I have to agree with Rich,
To note, a VFD aka (Variable Speed Drive -VSD) come these days with built in torque regulators especially on the single to 3-phase units. They are able to detect the motors actions and adjust the power settings accordingly. the great thing about a VSD drive is you can either set the start up speed from 1-30 sec so it will automatically step the power up to give you a more controlled start up and with your emergency stop or function you can set the motor to electronically brake from high speeds slowly, fast or even dead-stop (Which I would be scared of doing with a big chunk of wood anticipating to shoot off and cut me in half!)
I still use a belt driven late for my speed control but I am seriously thinking of upgrading my motor stock to a 3-phase 1Kw unit with an single phase-3 phase VSD drive.
Just a thought?
-- An unfinished project makes great firewood for winter!
View thughes37's profile
thughes37
23 posts in 2568 days
#4 posted 03-03-2011 04:55 PM
Hey army, for what it’s I own the Delta 46-460, has a 1hp motor with a 12” swing, and I LOVE IT! Woodcraft has this lathe on sale through today for $509. If funds are where you can swing it, that is a great deal. You can make your own stand and it’s more than enough lathe to turn what you are looking at doing. Just an idea.
-- All things are possible, only believe.
View TheDane's profile
TheDane
5367 posts in 3569 days
#5 posted 03-03-2011 05:32 PM
I would 2nd thughes37’s advice … the Delta 46-460 is rock solid. It is quite a bit more than the Rikon you are considering, but IMHO it is a tool that, depending on what you intend to do with it, you’ll be much happier with.
—Gerry
View Jack_T's profile
Jack_T
623 posts in 2938 days
#6 posted 03-03-2011 07:33 PM
Given the choice of the two lathes, I would buy the variable speed model. The documentation provided by the Woodcraft website states that it is an electronic variable speed.
-- Jack T, John 3:16 "For God so loved the world that he gave his only Son, so that everyone who believes in him might not perish but might have eternal life."
