Joint for plywood cabinet
Forum topic by daddywoofdawg posted 12-07-2017 05:03 AM 669 views 0 times favorited 14 replies Add to Favorites Watch
View daddywoofdawg's profile
daddywoofdawg
1028 posts in 1596 days
12-07-2017 05:03 AM
Topic tags/keywords: question joining
I’m building a shop cabinet to go under the table saw wing for sled,blades and other table saw stuff,I’m building out of BB ply,what is the best Joint for plywood cabinet? I thought about finger joints and would really think they would look sharp in this app but I can’t see how a person could hold upright a 24” x 30” piece of 1/2” ply to run it through the saw, and I don’t have a router style finger jig, So the two i can think of are pocket screws or mitered with splines.there a better ad fairly simple hard to mess up joint that would work?
14 replies so far
View jonah's profile
jonah
1720 posts in 3320 days
#1 posted 12-07-2017 05:16 AM
I’d do a rabbet or a simple butt joint with glue and screws, personally.
View AlaskaGuy's profile
AlaskaGuy
4201 posts in 2330 days
#2 posted 12-07-2017 07:47 AM
D
View Woodknack's profile
Woodknack
11758 posts in 2401 days
#3 posted 12-07-2017 08:18 AM
I don’t know the “best” but I know it isn’t going to matter unless you will be kicking it or rolling it down hills. You can butt joint them and they will be strong enough although rabbets help with alignment. So just go with whatever you are comfortable doing and I would add glue either way.
10476 posts in 3669 days
#4 posted 12-07-2017 08:40 AM
Tongue and groove can work well. It’s
not too difficult to cut with a table saw.
I use butt joints because it simplifies the
math but it does require some method
of alignment. I used used biscuits and
screws for awhile.
View rwe2156's profile
rwe2156
2956 posts in 1502 days
#5 posted 12-07-2017 04:10 PM
For something like this simple butt joints with glue and trim head screws. Fill the holes you won’t ever see them.
Rabbets would be a bit stronger and help with alignment, if you’re willing to do the extra work.
View Bill_Steele's profile
Bill_Steele
315 posts in 1753 days
#6 posted 12-07-2017 04:18 PM
I think a rabbet is a good choice—self aligning, easy to cut, lots of glue surface. If you do not want to see any of the plies—then I would consider a lock miter—self aligning, lots of glue surface.
View bondogaposis's profile
bondogaposis
4753 posts in 2373 days
#7 posted 12-07-2017 04:18 PM
I think the fingers would break really easy in plywood, unless they were quite wide. I honestly don.t feel you’d get much for your effort. I generally use butt joints and pockets screws for plywood cabs.
-- Bondo Gaposis
View Planeman40's profile
Planeman40
1179 posts in 2782 days
#8 posted 12-07-2017 04:44 PM
“Rabbit” (rebate) joints work well as well as spline joints. I like spline joints as they are easy to cut and easy to glue up. And they are strong.
View ArtMann's profile
ArtMann
950 posts in 838 days
#9 posted 12-07-2017 05:49 PM
I used pocket screws and butt joints in all my shop tables and cabinetry. As best I can remember, that was about 15 years ago. I have heavily used and overloaded those cabinets time and time again. I haven’t seen even a hint of failure. Some people say they are weak but you can use as many screws as necessary. The joint can easily be made stronger than dado and glue. The one thing you need to remember is that when you go to assembly, you need to have the joint clamped up tight as if you were trying to glue it together. The only reason I don’t use pocket screws a lot more is they aren’t very attractive.
View Rich's profile (online now)
Rich
2959 posts in 611 days
#10 posted 12-07-2017 05:50 PM
I’m not suggesting that finger joints would be the best choice, but Woodhaven has a portable box joint jig out that attaches to the board, rather than having to move the board across it.
https://www.infinitytools.com/woodhaven-portable-box-joint-jig-for-large-finger-box-joints-4872
View JBrow's profile
JBrow
1358 posts in 941 days
#11 posted 12-08-2017 01:35 AM
daddywoofdawg,
I like to use a dado/rabbet joint when building plywood boxes because the joints eliminate issues with varying thickness of plywood, are self-squaring joints, easy to cut accurately on the table saw, and offer a lot of gluing surface. In ¾” plywood the dados are 3/8” wide x 3/8” deep. The tongues are rabbets that are 5/16” deep and cut to fit the width of the dado. The edges of the tongues are slightly chamfered to aid in assembly. If the joints are all brought together snugly, the box will be square (if the bottom, top, back, sides and face frame are all cut square).
However, I am not sure enough material exists for this type of joint for ½” thick plywood. On ½” plywood the depth of the dado would be ¼” and the length of the mating tongue would be 3/16”.
Since there is so much glue to spread, slow-set glue is needed or assembling the box in steps is necessary; I assemble in steps. For example only the back, top, and the bottom are glued to the one side in the first glue-up. The second glue-up adds the second side. The final glue-up adds the face frame and completes the glue-up. In all glue-ups, the entire box is assembled and clamped even though some joints are unglued. Long-reach curved cauls are helpful in bringing the joints together.
woodbutcherbynight
4800 posts in 2430 days
#12 posted 12-08-2017 01:53 AM
Butt joint them but cut back a sliver and glue on a piece of wood slightly wider. When the glue dries trim it with a router. Like you would do Formica. The edge then will not show the exposed plys and fill. Not really needed but practice for when you do want it to look nicer with not fancy joinery.
View jbay's profile
jbay
2331 posts in 921 days
#13 posted 12-08-2017 02:03 AM
Dado, glue and screw.
A butt joint with pocket screws will never be stronger than this.
View MrRon's profile
MrRon
4793 posts in 3265 days
#14 posted 12-08-2017 05:39 PM
My vote is for a rabbet joint and dados where needed, as for shelves or dividers. It may sound like overkill to some, but to me it’s good practice for when the big job comes around.
