Delta Unisaw Tripping
Forum topic by Reaper417 posted 12-07-2017 02:40 AM 571 views 0 times favorited 10 replies Add to Favorites Watch
View Reaper417's profile
Reaper417
49 posts in 2329 days
12-07-2017 02:40 AM
Hey, I have a sort of weird question. My delta unisaw tripped tonight because I had a heater on and I can’t run both at once. So I turned off the heater reset the breaker and I thought I was good to go. Well after I cut my piece I went to turn it off and as I hit the off button it tripped the switch again and now I can’t turn it off. Is there some kind of reset inside the box or did I fry something. Thanks for your help in advance….Dave
10 replies so far
MrUnix
6846 posts in 2283 days
#1 posted 12-07-2017 02:42 AM
There is (should be) a manual reset in the starter. I’m guessing you meant to say you can’t turn it on, not off.
Reaper417
#2 posted 12-07-2017 04:09 AM
Brad, No I am right. I can’t turn it off. Every time I hit the off button it trips and when I reset it, it starts again. The only way to shut it down is to turn the breaker off or unplug it. I have the manual. I’ll look in there for the reset. Thanks
MrUnix
#3 posted 12-07-2017 04:40 AM
Then you shorted something somewhere. What kind of starter do you have? Need more info.
Reaper417
#4 posted 12-07-2017 06:28 AM
Not good with electric. I know its a 220 line. The box is fairly large and has a separate on and off switch. What else would you need?
MrUnix
#5 posted 12-07-2017 09:11 AM
Oh man, there are just too many different configurations to offer any real guidance here. Post some pictures and describe what it’s doing a bit clearer. Tripping? Tripping what? The circuit breaker in your panel? The overload on the Saw? Walk through what you do and what happens when. Was it working fine until you tripped the breaker when running the heater? Did it work after that and then stop later, or did it start acting up immediately after tripping the breaker? If immediately, it could have been a short in the saw that tripped the breaker, not the heater. Just too many unknowns here to really narrow it down much.
View Sparks500's profile
Sparks500
187 posts in 414 days
#6 posted 12-07-2017 01:24 PM
Stop feeding it mushrooms..
Seriously, what kind of breaker are you using? Running a straight resistive heat load on a breaker and combining it with a large motor surge may have damaged the breaker. Try using a different breaker if you have a similar one in the panel.
-- A good day is any day that you're alive....
Reaper417
#7 posted 12-07-2017 01:42 PM
The saw worked fine before. I can’t use both at the same time and I did and that’s when the breaker popped. I unplugged the saw and tried the heater and that was fine. Then I unplugged the heater and tried the saw. The saw started and then when I went to shut it off, that’s when the breaker tripped again. So I reset the breaker and the saw started running again. It never shut down just tripped the breaker.
View dhazelton's profile
dhazelton
2786 posts in 2380 days
#8 posted 12-07-2017 02:21 PM
Is it a magnetic switch? If so something is hung up in it and needs some cleaning.
View smitdog's profile
smitdog
386 posts in 2189 days
#9 posted 12-07-2017 02:36 PM
^That would be my first thing to check too. With the saw unplugged, don’t just trust the breaker turned off, open up the starter and see if the magnetic switch is still closed. It could be some grime has made it not able to move freely so it’s stuck in the on position. Read this thread for some ideas to look at.
-- Jarrett - Mount Vernon, Ohio
Reaper417
#10 posted 12-08-2017 04:39 AM
To everyone who helped me out with their suggestions, thank you. I had a friend come over and he took the starter out to look at it. So far he didn’t find anything wrong. He’s trying your ideas now. I’ll let you know the out come.
