Is this plane worth the repair?
Forum topic by PaBull posted 03-02-2011 10:15 PM 4208 views 0 times favorited 15 replies Add to Favorites Watch
View PaBull's profile
PaBull
956 posts in 3660 days
03-02-2011 10:15 PM
I am looking at possibly buying this plane. It is a Stanley #3, but it has a hairline fracture in the side of the metal base.
Can this be repaired? Or should it be repaired?
What does this do to the value of this plane?
Thanks for your help.
-- rhykenologist and plant grower
15 replies so far
10380 posts in 3643 days
#1 posted 03-02-2011 10:28 PM
Without the crack, worth between $100-$300 I’d say.
That’s not just a #3, it’s a Bedrock #3 which makes it a sought-after collectible.
The crack can be repaired with brazing. It may or may not diminish the value
of the plane to some collectors, but if you want to try using it the crack
should perhaps be fixed in some way. Where the crack is matters – some
cracks can be tolerated in a plane, some jeopardize the integrity of the
entire casting.
View DaddyZ's profile
DaddyZ
2475 posts in 3036 days
#2 posted 03-02-2011 11:28 PM
No its not worth anything – send it to me & i will throw it away for you ;)
PaBull
#3 posted 03-02-2011 11:35 PM
Thanks, Loren, yes it is a bedrock 603.
Rick, that is good information, i will check with a local welder.
DaddyZ, what’s your address?
Pabull.
DaddyZ
#4 posted 03-02-2011 11:54 PM
Busted !!! I really don’t use a plane that often, I deffinately don’t know how to fix it !!!
View b2rtch's profile
b2rtch
4861 posts in 3044 days
#5 posted 03-03-2011 12:19 AM
I use silver soldering quite often to solder high pressure copper air and water lines.
This is good stuff but expensive.
Using silver solder on a plane I would be concerned about distortions as it requires high temperatures
-- Bert
View Mura's profile
Mura
17 posts in 2674 days
#6 posted 03-03-2011 12:22 AM
Nice looking plane!
View dlmckirdy's profile
dlmckirdy
199 posts in 3129 days
#7 posted 03-03-2011 01:14 AM
I’ve done plenty of silver soldering. The plane would need to be stripped down to the body and the very end of the crack would have to be “stop drilled” to prevent cracking any further (about 1/16” dia. should do, if there are no radial cracks around it). Then it should be heated in an oven to between 500-750 degrees (SLOOOOOWLY). Then, while still hot, the joint would be silver soldered, including plugging the stopdrill. Then let it cool just as slowly with the sole resting on a flat surface (preferably as hot as it is). When it is naturally down to room temperature, inspect the entire body for other/new cracks (sometimes cast iron will crack as stresses relieve during heating or cooling). If there are no more cracks, file and polish it to like new condition, and the repair will hardly be noticable (If the iron begins to rust, the silver won’t, and will show up like a sore thumb, so keep it shiny!
-- Doug, Bakersfield, CA - I measured twice, cut it twice, and it is still too short!
PaBull
#8 posted 03-03-2011 01:33 AM
You have all talked me right out of buying this plane. Thanks for all your great advise. I had no idea it would this much skill to fix up this little plane. I just thought I found a steal of a deal.
But for the guys who want to know more about it, here is the link:
http://cgi.ebay.com/ws/eBayISAPI.dll?ViewItem&item=290539726062
The bid is $1.04 right now!!
View mafe's profile
mafe
11725 posts in 3084 days
#9 posted 03-04-2011 12:14 PM
I think also it’s a inside job!
And do understand that you dont walk that road…
Best thoughts,
Mads
View David Craig's profile
David Craig
2137 posts in 3104 days
#10 posted 03-04-2011 03:07 PM
Don’t feel too bad on missing out on this one. It is already almost 60 bucks in the bid and has two days left on it. If you would like to get familiar with planes and learn to fix them up, I would suggest starting with the Bailey’s. The old ones are really nice planes and can be picked up very reasonably.
David
View Bertha's profile
Bertha
13525 posts in 2688 days
#11 posted 03-04-2011 03:51 PM
I definitely wouldn’t bother repairing this plane but you could make some money parting it out. It’s a very desirable plane & the frog is what makes it so desirable. For me, it wouldn’t be worth the hassle unless I had another 603 lying around that needed a lever cap, etc.
PaBull
#12 posted 03-04-2011 10:21 PM
Thanks Mads, I agree, I am trying to walk that fine line, the narrow road. Not always easy. But no I am not one of the insiders.
David, I saw that, maybe my own doing, now the world knows about this plane.
Bertha, it is all yours, I am going on. I have a nice smooth Stanley #3 I will be sticking with. And after this, my Stanley is looking much better.
Thanks for all your input. It is so nice to have this support when you are not sure about a purchase.
Pabull.
Bertha
#13 posted 03-04-2011 10:29 PM
PaBull, there’s nothing shabby about a vintage #3. In my opinion, you don’t really enjoy the benefits of the bedrock design in the smaller planes. I’ve got a Sweetheart #4 that I like better than my 604. Now a big 607, you might be getting your money’s worth. I like the look of the flat-walled Bedrocks over the curved wall ones, which are probably superior in quality. Who ever knows, right? But you’re right about one thing, it’s really cool to have a gang of plane freaks to consult with.
16274 posts in 4214 days
#14 posted 03-04-2011 10:50 PM
I looked at the link…
Are we sure the seller is talking about cracks in the body and not the hairline cracks which are noticeable on the tote?
PaBull
#15 posted 03-04-2011 11:25 PM
Q: Does that mean splits in the wood, or any cracks in the cast iron?
A: Please look at pictures 6 and 8. There appears to be a stress line in the metal and a hairline at the bottom of the large wood handle. Otherwise it is pretty solid.
This might answer your question, Charley.
