Drawer bottoms
Forum topic by Bohaiboy posted 12-06-2017 12:18 AM 580 views 0 times favorited 5 replies Add to Favorites Watch
View Bohaiboy's profile
Bohaiboy
76 posts in 2032 days
12-06-2017 12:18 AM
Making drawers and have a question about the bottoms. Actually how to connect the bottoms to the sides. THis is for a jewelry cabinet so the drawers will hold minimal weight. I plan on using 14” ply for the bottoms.
My question is whether to cut rabbits on the bottom of all sides or to ffset 1/4” and cut a dado. The drawers will be about 3” tall each.
-- Tim, Houston, TX area
5 replies so far
View Ron Aylor's profile
Ron Aylor
2649 posts in 885 days
#1 posted 12-06-2017 12:48 AM
Hi Tim … not sure if this will help, but I do drawers like this ... read about half-way down the page. This drawer was about 2-1/2” tall.
View Texcaster's profile
Texcaster
1286 posts in 1912 days
#2 posted 12-06-2017 12:56 AM
Drawer slips are always elegant and thin back and sides can be used, making dovetails easier. For a box, all corners must be mitred.
Images 7,8, and 9 are the easiest to understand.
https://www.google.com.au/search?q=drawer+slips&sa=X&rlz=1C1SFXN_enAU512AU672&tbm=isch&tbo=u&source=univ&ved=0ahUKEwi0mbf6lfTXAhUIQLwKHbrJCgoQsAQILQ&biw=1280&bih=893
-- Mama calls me Texcaster but my real name is Mr. Earl.
View LesB's profile
LesB
1918 posts in 3681 days
#3 posted 12-06-2017 01:25 AM
Having just done something like that my self I would go with the dado on 3” tall drawers. However you did not indicate how thick the sides were and that could make a difference.
Now that I recommended that I have to admit I used rabbits on mine….LOL
-- Les B, Oregon
View bandit571's profile
bandit571
21999 posts in 2921 days
#4 posted 12-06-2017 02:43 AM
One could look up the two dressers I have done this year…
Front corners are dovetailed
Back goes into a dado cut into the sides
Bottom fits into grooves along the bottom edge…..1/4” up from the bottom of the drawer, groove depth is half of the thickness of the sides. Bottom slides under the back. Glue and a screw or two. to hold the bottom in place at the back.
View EricLew's profile
EricLew
228 posts in 1604 days
#5 posted 12-07-2017 04:24 AM
I always put the drawer bottom in a groove. I have the Whiteside undersized plywood router bit set, and its so simple, and the plywood fits perfectly. One pass at the router table and you’re done. Of course on a 3” drawer you may not be willing to lose 1/2” of depth, so rabbets would also work fine, but then you have to glue, nail, or staple
-- I love the smell of coffee in the morning, and sawdust in the afternoon
