convince me to keep my jointer
Forum topic by AaronK posted 12-05-2017 06:21 PM 1553 views 0 times favorited 46 replies Add to Favorites Watch
View AaronK's profile
AaronK
1507 posts in 3578 days
12-05-2017 06:21 PM
Topic tags/keywords: jointer
So I’ve got a 6” jointer (yorkcraft)... haven’t used it in at least a year, maybe 2 (i really don’t remember the last time). I’ve been doing edges with handplanes, and faces with a quick handplaning of the high spots and then running through the planer.
Any reason I shouldn’t sell it and free up the floor space and cash?
I’ve posted this in power tools instead of hand tools, thinking you guys could probably do a better job convincing me that those neanderthals ;-)
46 replies so far
View JCamp's profile
JCamp
795 posts in 664 days
#1 posted 12-05-2017 06:29 PM
Better to have it and not need it than need it and not have it
If space is an issue id sell that one and get a smaller 4inch… but im bias, I do not have one and see how I could use one all the time LOL
-- Whatsoever thy hand findeth to do, do it with all thy might
View AZWoody's profile
AZWoody
1393 posts in 1338 days
#2 posted 12-05-2017 06:30 PM
You don’t use it because it’s too small and you need an 8” or 12” :)
Woops, that’s probably not what you wanted to hear ;)
View EarlS's profile (online now)
EarlS
1512 posts in 2462 days
#3 posted 12-05-2017 06:33 PM
It sounds like you enjoy hand planing edges. Me? Not so much. I have a 6” delta jointer and I use every time I make dimensional lumber from rough stock. The sharp 90 degree edge along the flat planed board means I don’t have to worry if the board will butt up tightly against another one if I’m gluing up wide stock. If I’m running it through the table saw I know the edge will be square and straight against the fence. I can tip the fence and make very accurate bevel cuts even better than on the table saw. I can hook it up to my dust collector and not have a big pile of shavings to clean up when I’m done.
All in all, I prefer the consistency, accuracy, and speed of a jointer to make edges for my boards.
That’s all I’ve got for reasons. Probably more if I really think about it.
View bondogaposis's profile
bondogaposis
4925 posts in 2465 days
#4 posted 12-05-2017 06:41 PM
Why, if you don’t use, sell it. You can always get another if you change the way you work.
-- Bondo Gaposis
AaronK
#5 posted 12-05-2017 08:30 PM
I should say, I think my jointer’s fence is slightly twisted – i seem to get different results depending on where i apply pressure. I’ve aligned it so that it’s square right over the cutterhead… but it’s very much a manual, techniqu-ey process. And if i need technique, i might as well do it by hand – at least there’s no dust.
I feel like the 6” size is too narrow and beds too short to be good for large stock, and if it’s small stock, it goes almost as fast by hand.
maybe I DO need an 8+” :D
View Brit's profile
Brit
7449 posts in 2957 days
#6 posted 12-05-2017 08:45 PM
The only 8 you need Aaron is a No.8. :o)
-- https://www.clickasnap.com/Andy61 - Andy - Old Chinese proverb says: "If you think something can't be done, don't interrupt man who is doing it."
View William Shelley's profile
William Shelley
576 posts in 1583 days
#7 posted 12-05-2017 09:02 PM
You don t use it because it s too small and you need an 8” or 12” :)
Woops, that s probably not what you wanted to hear ;)
- AZWoody
12” ????
You spelled 16” wrong.
-- Woodworking from an engineer's perspective
View rbrjr1's profile
rbrjr1
170 posts in 319 days
#8 posted 12-05-2017 09:16 PM
I’ve always wanted one, now I have one.. I like it when that happens..
-- only an idiot dismisses an intelligent statement because they dont know anything about the person delivering it.
View JayT's profile
JayT
5806 posts in 2325 days
#9 posted 12-05-2017 09:23 PM
haven t used it in at least a year, maybe 2 (i really don t remember the last time).
- AaronK
I think you already know the answer for you. I find a jointer to be the least needed piece of power equipment in a shop, as anything it can do can also easily be done by other means and you are already doing so. Someone else who works in a different manner may argue a different point, but they aren’t the ones in your shop. If you aren’t using it, why keep it around?
View LesB's profile
LesB
1801 posts in 3557 days
#10 posted 12-05-2017 09:25 PM
Like you I seldom use mine but I have room in the shop for it so I keep it. I usually only use it to clean up the edge of a board….especially if my table saw is set up for something else.
I find my Table saw does a great job of giving me a nice clean straight edge on my boards.
-- Les B, Oregon
View DMC1903's profile
DMC1903
285 posts in 2441 days
#11 posted 12-05-2017 09:28 PM
After purchasing a TS 75 and numerous bevel up Veritas planes, I rarely used my jointer. The Track saw cuts very nice edges and quality hand planes speak for themselves.
I sold my dusty used jointer, created more space in the shop…..No regrets
View Carloz's profile
Carloz
1147 posts in 705 days
#12 posted 12-05-2017 10:24 PM
- JCamp
Right! If you do not need a jointer sell it … and buy another one!
View Roy Turbett's profile
Roy Turbett
168 posts in 3694 days
#13 posted 12-05-2017 10:52 PM
I was in the exact situation a year ago and got rid of mine. I use hand planes for face surfacing, and edge jointing when I’m not in a hurry. I use my router table for edge jointing when I’m in a hurry or have a lot of stock. I use a flush cutting bit and a piece of formica for a shim on the out-feed side. It gives a much better edge than I ever got with my 6” Ridgid jointer.
View AAL's profile
AAL
75 posts in 1540 days
#14 posted 12-05-2017 11:08 PM
It sounds like you enjoy hand planing edges. Me? Not so much. I have a 6” delta jointer and I use every time I make dimensional lumber from rough stock. The sharp 90 degree edge along the flat planed board means I don t have to worry if the board will butt up tightly against another one if I m gluing up wide stock. If I m running it through the table saw I know the edge will be square and straight against the fence. I can tip the fence and make very accurate bevel cuts even better than on the table saw. I can hook it up to my dust collector and not have a big pile of shavings to clean up when I m done.
That s all I ve got for reasons. Probably more if I really think about it.
- EarlS
I agree with this completely. Planes are to fly in!
-- "Socialism is a philosophy of failure, the creed of ignorance, and the gospel of envy, its inherent virtue is the equal sharing of misery." Winston Churchill
View fuigb's profile
fuigb
501 posts in 3071 days
#15 posted 12-05-2017 11:27 PM
If space and money really are problems then it’s off with its head. But will the little money that it brings really change things? Your shop is in a U-boat and so every centimeter is precious? Only the OP can answer.
I want to get rid of my 6” Rigid jointed but for ideological reasons: I want to go power-free. But this won’t happen until I retire and can build up my weak skills.
-- - Crud. Go tell your mother that I need a Band-aid.
showing 1 through 15 of 46 replies
