Most LOVE a good hummer...
Forum topic by richardchaos posted 12-05-2017 12:30 PM 593 views 0 times favorited 7 replies Add to Favorites Watch
View richardchaos's profile
richardchaos
583 posts in 619 days
12-05-2017 12:30 PM
I have a Cobalt Diaphragm air compressor. Its very loud and annoying when it goes off. I was thinking of making a BOX for it in the corner of my shop with some sort of noise dampening material on the inside of this box.
Dos anyone know what material I could use that is effective and CHEAP?
-- “In a time of universal deceit, telling the truth is a revolutionary act.” ― George Orwell
7 replies so far
woodbutcherbynight
5832 posts in 2648 days
#1 posted 12-06-2017 03:22 AM
We tried this at a mechanics shop I worked at. Used various types of insulation, sound barrier stuff etc etc. Enclosed it nice and tight like the manager told us. Burned the compressor out from overheating, as in no ventilation. So two options. Do so but make sure you have fresh air supply to this box. Or make a box outside and run a pipe through to the inside. Insuring you have your box vented.
I have mine this way with a relay that turns a fan on when the compressor fires off drawing air across the box and to the outside. Used a layer of regular insulation and some scrap 3/4 foam board between the walls. Both walls are 3/4 plywood thick. Yes I can hear it but nothing like sitting on top of it in my echo chamber. All the air lines are tucked away out of sight and mind with ends coming out in various places.
View shipwright's profile
shipwright
8187 posts in 3037 days
#2 posted 12-06-2017 04:24 AM
Check out California Air products. I switched to one of their compressors and now would have nothing else. They are soooooo quiet!
http://www.californiaairtools.com
View MrRon's profile (online now)
MrRon
5273 posts in 3483 days
#3 posted 12-06-2017 06:43 PM
I think the sound absorbing material that is used in loudspeaker cabinets would work well. I’m not sure what the material is; shouldn’t be too difficult to find out from the internet.
View JoeinGa's profile
JoeinGa
7740 posts in 2246 days
#4 posted 12-06-2017 07:13 PM
How about build a small enclosure on the outside of your shop. Here’s what I did …
More details at this link http://lumberjocks.com/JoeinGa/blog/42595
richardchaos
#5 posted 12-06-2017 08:04 PM
Thats a good idea I am considering it. Someone told me a cheap insulation is carpet padding
How about build a small enclosure on the outside of your shop. Here s what I did …
- JoeinGa
View FirehouseWoodworking's profile
726 posts in 3513 days
#6 posted 12-07-2017 02:22 AM
A good and “inexpensive” material to use for noise abatement in a compressor cabinet/room is old fashioned egg cartons. I had my compressor closet in my previous shop lined with them and the noise difference was amazing. I also used them to abate the noise of the small vacuum that I have under my router table these last 40 years!
The best ones to use are the grey ones made from paper and cardboard pulp. You just use the carton bottoms and cut off the tops.
If your are friends with a cook at a restaurant, you might be able to land some of the egg flats that hold two dozen eggs.
Cheers!
-- Dave; Lansing, Kansas
View BHZ's profile
BHZ
19 posts in 1218 days
#7 posted 12-07-2017 05:25 PM
I used acoustic ceiling tiles (for hanging ceilings 2’ X 4’) and that seems to work well.
