Attaching a Mirror to a Small Box Lid
« back to Joinery forum
Forum topic by cowboyup3371 posted 12-05-2017 12:25 PM 660 views 0 times favorited 10 replies Add to Favorites Watch
View cowboyup3371's profile (online now)
cowboyup3371
63 posts in 436 days
12-05-2017 12:25 PM
I’m about at a finished point with the music boxes and looking to do a couple of things, one of which is to glue the mirrors on to the lids. I intend to stain the wood first with an Ebony color than glue the mirrors on. I found the posts mentioning “mirror glue” but the only stuff I can find locally is the Liquid Nails. As I only have a couple of weeks to Christmas, I really don’t want to have to wait too long for a mail order to arrive. Will that stuff work or should I be looking at something else?
Also, the last time I did this type of project, the mirror fell off after about a year or two. Is there a better way to ensure it stays on or will I just have to re-attach it every so often?
-- Cowboy Up or Quit - If you are going to quit than get out of my way
10 replies so far
View Lazyman's profile
Lazyman
2707 posts in 1625 days
#1 posted 12-05-2017 12:45 PM
Might be too late to adjust your current design but I would have made the lid as a frame that holds the mirror the same way you would for a glass pane.
View poospleasures's profile
poospleasures
782 posts in 2722 days
#2 posted 12-05-2017 12:46 PM
I always make a small wood frame for the glass which can then be glued or pin nailed to the box. You can go to my projects to see some examples.
-- I,ve had amnesia for as long as I can remember. Vernon
View AandCstyle's profile
AandCstyle
3185 posts in 2495 days
#3 posted 12-05-2017 09:54 PM
Cowboy, I used T88 epoxy on one I did. So far so good, but it has only been about 6 months. I left an area unfinished in the center of the mirror so the epoxy would be attaching to bare wood. Be careful to not use too much epoxy or it will squeeze out around the edge of the mirror. DAMHIKT
-- Art
View AAL's profile
AAL
80 posts in 1664 days
#4 posted 12-05-2017 10:02 PM
Is the surface on the rear of the mirror typical, does it have any texture to it, or is it really smooth? 5-minute Epoxy should serve you well for most surfaces as it will bond to most surfaces.
-- "Socialism is a philosophy of failure, the creed of ignorance, and the gospel of envy, its inherent virtue is the equal sharing of misery." Winston Churchill
cowboyup3371
#5 posted 12-06-2017 04:08 AM
Thank you all. I almost picked up the T88 epoxy but at the last minute chose to use double sided tape. We’ll see how things work out.
View BurlyBob's profile
BurlyBob
6031 posts in 2503 days
#6 posted 12-06-2017 04:34 AM
I used silicon caulk to glue to some mirror to a wall scones. A pair are hanging over my fireplace as I type this. We’ve had no problems.
View Andre's profile
Andre
2362 posts in 2044 days
#7 posted 12-06-2017 06:56 AM
! + to the Silicone, did a wardrobe for the Granddaughter and talked to the glass shop about the danger of the large mirror possible breaking and they told me just to use Silicone over the entire back and no worries about any
of the glass coming of in case it breaks. Just use a notched glue spreader and install it like a tile.
View 000's profile
000
2859 posts in 1137 days
#8 posted 12-06-2017 02:22 PM
Mirrors are made with different kinds of backings on them.
Clear silicone can eat through some of the backings after a years or so, maybe less.
I’ve always stayed away from clear silicone.
Black is OK.
Big box stores carry this that works also.
View oldnovice's profile
oldnovice
7380 posts in 3606 days
#9 posted 12-06-2017 11:50 PM
Have you considered small decorative cleats to hold the mirror?
The cleats could be metal or wood and could be nailed, screwed, or glued to the top.
Considering that the color is ebony, how about some bright brass cleats?
cowboyup3371
#10 posted 12-07-2017 04:24 AM
Thank you for all of the information. I’ll do some looking for the cleats as I like the idea of them but didn’t see any at my local Woodcraft. It might be a reason to go find the Rockler store in Cincinnati
