Tung Oil mixed with Mineral Spirits
Forum topic by riverb posted 03-02-2011 05:34 AM 17430 views 0 times favorited 19 replies Add to Favorites Watch
View riverb's profile
riverb
45 posts in 2639 days
03-02-2011 05:34 AM
Topic tags/keywords: finishing
I am finishing a crib for my daughter with tung oil and have mixed it 50/50 with mineral spirits. Will mixing it allow me to put coats on faster? When I was using pure Tung Oil it would take 24+ hours between coats.
19 replies so far
View ocwoodworker's profile
ocwoodworker
209 posts in 2969 days
#1 posted 03-02-2011 05:45 AM
Actually I have done just that. The 50/50 is a great way to start the first coat. It lowers the viscosity and allows a deeper penetration via capillary action. It does dry quicker but the caviot is that there is less tung oil applied therefore more coats are needed. It’s a six in one hand & half a dozen in the other. The only upside is the deep luster it gives over a standard application. Also just to keep in mind, the tung oil already is semi-diluted. So more than 50/50 is just wasting mineral spirits.
-- I'd like to believe Murphy's Law haunts my woodshop, because if it's Karma it would mean I had something to do with it. - K.R.
View docholladay's profile
docholladay
1287 posts in 3023 days
#2 posted 03-02-2011 05:46 AM
It should dry faster after thining like that, but the trade off is that the coats will also be thinner and therefore more coats will be required to achieve a finish build. My personal favorite mixture for a wipe on finish is 1/3 tung oil, 1/3 oil based polyurethane and 1/3 mineral spirits. I builds a finish in about 4 or 5 coats and still dries fairly quickly. Depending on humidity and temperature, it will dry within 3-6 hours.
Doc
-- Hey, woodworking ain't brain surgery. Just do something and keep trying till you get it. Doc
View Bearpie's profile
Bearpie
2601 posts in 2982 days
#3 posted 03-02-2011 05:46 AM
I am not sure if I would use that mixture on a baby crib! I recall my own 2 daughters with their mouths on the rails and bars working their teeth and gums on the wood. I think I would do more research and come up with a safer solution. Just my 2 cents!
Erwin, Jacksonville, FL
-- Erwin, Jacksonville, FL
View MOJOE's profile
MOJOE
548 posts in 3233 days
#4 posted 03-02-2011 05:56 AM
If I recall from reading similar posts with concerns about the safety of various finishes, I think viturally all finishes are safe as long as they are fully cured…..probably still worth a little research since the kiddos are involved though.
-- Measuring twice and cutting once only works if you read the tape correctly!
View Don's profile
Don
517 posts in 3037 days
#5 posted 03-02-2011 06:42 AM
For a baby crib I’d use something food safe, like shellac or anything designed for cutting boards.
-- Don - I wood work if I could. Redmond WA.
View Cornductor's profile
Cornductor
208 posts in 2631 days
#6 posted 03-02-2011 05:45 PM
I’ve been using Danish oil from triedandtrue and that stuff is great. I recently used it on some chess boards and it turned out really well. The dry time was a few hrs but all in all I really enjoyed using there product.
-- An investment in knowledge pays the best interest. Benjamin Franklin
View bobsmyuncle's profile
bobsmyuncle
110 posts in 2656 days
#7 posted 03-03-2011 05:08 AM
Take a look at Popular Woodworking, July 2005 issue titled “FINISHING &
REFINISHING.” In this issue is an article written by Bob Flexner, “The Folly of Food-safe finishes”
Two quick excerpts from the article:
1. “The issue of food safeness in finishes is a classic case of the concept
“validation by repetition.” Consistent, long-term repetition in woodworking
magazines of a food-safeness issue, despite the complete lack of supporting
evidence, has lead to a widely held belief in the woodworking community that
food safeness is an issue.”
2. “But, based on FDA regulations, the way finishes are made, the complete
lack of any evidence to the contrary, and the countless other untested
objects food and children come in contact with, there’s no reasonable
argument for avoiding the use on any finish.”
Cornductor
#8 posted 03-03-2011 05:58 AM
Huh?
View Don's profile
Don
#9 posted 03-03-2011 09:26 AM
My “reasonable argument for avoiding” certain finishes with something that a child will chew on is that I don’t need proof that it’s not safe, I need proof that it is safe. Shellac is edible, Tung oil is not. If I build a crib for my own child I’m using shellac, not Tung Oil.
View tenontim's profile
tenontim
2131 posts in 3709 days
#10 posted 03-03-2011 02:33 PM
I used pure tung oil (not tung oil finish) on my grand daughters crib. Pure tung oil is food safe, once the mineral spirits evaporate. Start out with a 50/50 mix to speed the application, like previously mentioned. As you add more coats, reduce the amount of mineral spirits(or you can use citrus solvent, if you want to go totally food safe). You might want to give it more than 24 hours between coats, unless you’re in a hot, dry place. You will probably want to get about 8 – 10 coats on it.
View hObOmOnk's profile
hObOmOnk
1381 posts in 4092 days
#11 posted 03-03-2011 03:09 PM
Some water is drinkable, therefore ALL water is drinkable.
-- 温故知新
docholladay
#12 posted 03-03-2011 03:29 PM
I think it could be argued that Boiled Linseed Oil is not “food” safe. Boiled Linseed Oil, as opposed to Raw Linseed Oil, has drying agents added that are definitely considered to be poisonous (this is also true of some other natural oil based finishes including tung oil and danish oil). These “drying” agents are made from heavy metals and they do NOT evaporate away during the curing process. However, the opposite argument could be made that it is safe because with BLO, the finish primarily penetrates into the wood and does not build a film on the wood. Also, in order to reach a toxic level in most humans, you would almost have to drink the uncured finish so, it probably is safe enough.
Doc
tenontim
#13 posted 03-03-2011 03:52 PM
View Mario's profile
Mario
171 posts in 3361 days
#14 posted 03-03-2011 03:59 PM
You don´t need to thin tung oil with MS, just warm it up in a double boiler setup, it will readily penetrate the wood and dry a lot faster ;)
I agree that shellac is more suitable for a crib, being a film finish it will seal the surface and make cleaning a lot easier.
View Bill White's profile
Bill White
4902 posts in 3925 days
#15 posted 03-04-2011 05:42 PM
“Food safeness?” What the he(( has happened to the English language? Those are the most “unreadable” statements I encountered in quite some time.
Bill
-- bill@magraphics.us
