Triton Router tra001 plunge stop is the worst
Forum topic by lennyk posted 12-04-2017 10:32 PM 1184 views 0 times favorited 1 reply Add to Favorites Watch
View lennyk's profile
lennyk
32 posts in 948 days
12-04-2017 10:32 PM
I recently bought a triton tra001 router
wanted a little more power, it seems to have had good reviews over the years.
Started using it this weekend to do some dados for a couple nelson slat benches I am building.
It uses some plastic nuts on a bolt/screw as the punge stop.
Worked fine for one day and then all of a sudden the nuts appear to no longer be tight and are moving on their own with the vibration.
The router is a pretty good router, powerful, had nice mechanisms for plunging
but the most important part is very faulty, so therefore it is a rather crappy router.
I guess I will have to make up something with a set screw of some sort to prevent it from moving.
I am a very unhappy camper.
1 reply so far
View pintodeluxe's profile
pintodeluxe
5739 posts in 2929 days
#1 posted 12-04-2017 10:51 PM
I wouldn’t give up on it just yet. Order another pair of nylon nuts from Triton, or find matching hardware. Install two nuts on each threaded rod to function as a jam nut.
I had to do that on a dovetail jig that kept coming loose.
Good luck with it!
