Bed frame tolerance
Forum topic by Pabs posted 12-04-2017 07:50 PM 608 views 0 times favorited 12 replies Add to Favorites Watch
View Pabs's profile
Pabs
259 posts in 3689 days
12-04-2017 07:50 PM
hey guys
About to start a bed project. Making a bed frame for my girlfriend’s son.
he’s getting a full/double mattress (75” long and 54” wide)
here’s the model I’ll be copying
extremely simple design but I’m wondering what the space tolerances are for something like this. would you make the inside measurement to math the mattress exactly or leave a bit ? 1/4” or 1/2” extra overall maybe? in my mind exact would work and keep the mattress snug and keep it from moving any.. but figured I would ask in case there’s something obvious I’m not thinking about and will regret once boards are cut :)
thanks
P
-- Pabs
12 replies so far
View bondogaposis's profile
bondogaposis
5149 posts in 2587 days
#1 posted 12-04-2017 08:00 PM
Get the mattress first, then you will know.
-- Bondo Gaposis
View Pabs's profile
Pabs
#2 posted 12-04-2017 08:11 PM
well, access to mattress is difficult as it’s rolled up (high density foam). if I open It will expand and make it hard to get to her house after :)
-- Pabs
View Monte Pittman's profile (online now)
Monte Pittman
30132 posts in 2574 days
#3 posted 12-04-2017 08:28 PM
I allow 1” extra for total width and total length for tolerance. I make the lip 2” over the deck.
View DS's profile
DS
3044 posts in 2656 days
#4 posted 12-04-2017 09:03 PM
You want to allow some room for the bed sheets and access for tucking them in, etc.
I am with Monte on this one – about 1” each way.
No need to make it recess very deep into the frame though – just a couple inches.
(@Monte – you’ve done this before!!!)
View Woodknack's profile
Woodknack
12455 posts in 2616 days
#5 posted 12-05-2017 02:03 PM
Call the mattress manufacturer.
View johnstoneb's profile
johnstoneb
3070 posts in 2408 days
#6 posted 12-05-2017 02:07 PM
Measure the mattress. Mattresses are never the advertised size they can vary as much as 2” or more. DAMHIKT
-- Bruce, Boise, ID
View Mikesawdust's profile
Mikesawdust
327 posts in 3275 days
#7 posted 12-05-2017 02:08 PM
one inch should be fine, I might stretch it to 1.5 on length if the footboard is high, winter blankets are thick
-- You never cut a piece to short, you are just prepping that piece for a future project
View pontic's profile
pontic
663 posts in 844 days
#8 posted 12-05-2017 02:15 PM
If the box spring protrudes above the frame just make it 1/2” tolerance. The mattras will not be effected by thick bedding if this is the case.
If not then use 1.5” tolerance if you are in wintrey climates.
-- Illigitimii non carburundum sum
View dhazelton's profile
dhazelton
2805 posts in 2532 days
#9 posted 12-05-2017 02:19 PM
Only issue I see with setting the foam mattress down into a short box is that his hands will get all banged up against the lip that is essentially the rails. I would round them over or else it’s gonna end up scraping some knuckles.
View Kaleb the Swede's profile
Kaleb the Swede
1880 posts in 2205 days
#10 posted 12-05-2017 02:52 PM
I left 1 inch extra for the mattress for our bed. Worst case you could add a spacer to take it up if the mattress is much shorter.
Looks like a nice gift for your girlfriends son
-- Just trying to build something beautiful
View jonah's profile
jonah
1972 posts in 3534 days
#11 posted 12-05-2017 03:15 PM
I knew the exact size of my mattress, so I went with a total of 1” (1/2” either side and front/back) of extra clearance on my bed build. If I didn’t know the mattress, I’d probably go with the crowd and put 1” of extra room on all sides.
View Pabs's profile
Pabs
#12 posted 12-05-2017 03:37 PM
some great tips gang, I’ll go the extra inch as many have suggested
thanks!
-- Pabs
