Problem with ArmRSeal
Forum topic by perfesser posted 12-04-2017 06:32 PM 484 views 0 times favorited 9 replies Add to Favorites Watch
View perfesser's profile
perfesser
9 posts in 359 days
12-04-2017 06:32 PM
Anyone else have problems getting Arm-R-Seal to dry to a nice smooth coat in their 60F degree basement this time of year? The piece I finished with one coat and let dry in the garage over a month ago looks great, I can’t get the same finish out of anything since it’s gotten cold and I’ve had to evacuate the garage. I’m thinking 40F is worse than 60F even. I’m also guessing the RH is lower in the house basement.
-- in the garage, making sawdust..
9 replies so far
View bondogaposis's profile
bondogaposis
4770 posts in 2380 days
#1 posted 12-04-2017 06:36 PM
If you can get the temp up to 65°F you will have better luck.
-- Bondo Gaposis
View jonah's profile
jonah
1727 posts in 3327 days
#2 posted 12-04-2017 06:38 PM
A space heater will help take the edge off the cold and make things better. I’ve not had any problems at ~55-60F, but lower than that I could see being a problem.
perfesser
9 posts in 359 days
#3 posted 12-04-2017 07:58 PM
the surface is ending up almost gritty as opposed to smooth. very strange. no visible puckering or crazing or anything like that but after drying over night just doesn’t feel smooth. First piece from the garage drying is awesome!
bondogaposis
#4 posted 12-04-2017 08:05 PM
Possibly due to dust settling on the finish before it cures, the slower it cures the more dust can fall on it.
-- Bondo Gaposis
perfesser
9 posts in 359 days
#5 posted 12-04-2017 08:07 PM
gritty on the bottom? I understand on the top. but this is any side. just strange. but it is my first time using Arm-R-Seal also.
View Rich's profile
Rich
3028 posts in 618 days
#6 posted 12-04-2017 08:32 PM
Be sure to strain it before you apply it, particularly if it’s a can that’s been opened already. Also, while some heat would help, just getting the air moving makes a huge difference. If you have a couple of fans around, fire them up. It doesn’t need too point right at the finish, just get the air circulating around it.
perfesser
9 posts in 359 days
#7 posted 12-14-2017 10:15 PM
Well the good news is the last piece turned out great! I’m very happy with the last finish on it.
Only thing is how do you avoid getting “dots” on the bottoms from the little drying pyramids. LOL
John
View Rich's profile
Rich
#8 posted 12-14-2017 10:31 PM
John
- perfesser
You can make a pin board with sharper tips to support the board. I make them by shooting narrow gauge staples up through some plywood, but I’ve seen pros like Jeff Jewitt and Tom Johnson make them using drywall screws, which have a very sharp tip.
Of course the trick is to finish the back side first, so that when you flip it over, any marks left by the pins are on the back and you have a clean coat on the front.
View wood2woodknot's profile
wood2woodknot
95 posts in 2002 days
#9 posted 12-15-2017 01:33 AM
How big is the piece? Can itbe tented or covered with a large box? A light bulb safely enclosed with it might give enough warmth to help dry it quicker. Just make sure the lamp is far enough away from anything combustible. Remember leaving a light under your car in zero weather?
-- ajh
