Are full kerf blades more dangerous than thin kerf ?
Forum topic by Carloz posted 12-04-2017 02:13 PM 838 views 0 times favorited 17 replies Add to Favorites Watch
View Carloz's profile
Carloz
1147 posts in 709 days
12-04-2017 02:13 PM
I would guess that the ability to give in some would decrease a chance of pinching the wood between the blade and the fence.
Another thing is that when the blade does grab the wood the wider tooth has more wood to push against and as the result the wood will be thrown with bigger force. Thinner kerf would simply cut into the wood more and the wood would get less acceleration. You can picture it as cutting a watermelon with a thin and thick swords. The thin one will leave the watermelon halves in place but the thicker one will throw them to the side.
These are all purely my imagination that could be far from the real state of things.
17 replies so far
View jonah's profile
jonah
1837 posts in 3416 days
#1 posted 12-04-2017 03:40 PM
It’s your imagination. The only difference is that full kerf blades are likely stiffer, which would actually make them safer, not more dangerous, because they’d be less likely to deflect away from and then back into a pinched work piece.
Either one, when spun at ~5000rpm by a 1.5-5HP motor, will fling a piece of wood through a wall (or the operator of the saw).
View Lazyman's profile
Lazyman
2386 posts in 1504 days
#2 posted 12-04-2017 03:46 PM
Everything else being equal, besides the width of the blade, the biggest factors that cause risk are how well the saw is setup and the skill or stupidity of the operator.
View DalyArcher's profile
DalyArcher
115 posts in 1236 days
#3 posted 12-04-2017 03:53 PM
I doubt that is it actually measurable to any degree, but my thought would be the same as Jonah, full kerf blades may actually be safer. Again though, I doubt it is actually a measurable difference. Kickback will happen no matter the thickness or diameter of the blade if there is an error in operation. When I finally (hopefully by spring) get my 5 hp cabinet saw set up and running it will be sporting full kerf blades and Jess-Em stock guides.
5069 posts in 2610 days
#4 posted 12-04-2017 04:13 PM
You’re comparison the the thin/thick sword isn’t valid, as I see it. A saw blade removes the material to make way for it to pass though the wood, a sword doesn’t do that. Regardless, any difference would only be measurable with laboratory instruments and of no consequence to a hobbyist.
Carloz
#5 posted 12-04-2017 04:15 PM
, because they d be less likely to deflect away from and then back into a pinched work piece.
- jonah
What do you mean by “and then back into a pinched work piece” ?
View pintodeluxe's profile
pintodeluxe
5739 posts in 2930 days
#6 posted 12-04-2017 04:27 PM
If anyone has the impression that full kerf blades are more dangerous, I’ll bet it’s because they sometimes slow down on underpowered saws. Back when I was using a 1.75 hp contractors saw, I felt much better using a thin kerf blade because it was a better match to my saw.
jonah
#7 posted 12-04-2017 04:48 PM
- jonah
- Carloz
Full kerf blades are thicker. Being thicker, it’s harder to deflect one to the side. A blade deflecting away from the fence and then back into it (maybe due to a knot, or work fed improperly, for example) could cause a kickback.
View rwe2156's profile
rwe2156
3069 posts in 1598 days
#8 posted 12-04-2017 04:52 PM
Anything that causes you to push the stock harder increases the risk of an accident a lot.
This includes dull blades, underpowered saws, wood binding in the cut, poor quality fences, etc.
So I can see where a full kerf blade in an underpowered saw would be more dangerous when the blade gets a little dull.
How much more dangerous than a thin kerf? Who knows?
runswithscissors
2818 posts in 2142 days
#9 posted 12-04-2017 10:47 PM
I would never cut a watermelon with a sword. An axe, maybe, but never a sword.
Carloz
#10 posted 12-05-2017 12:03 AM
- rwe2156
It is not a matter of power. Wood offers more resistance when pushed against a full kerf than against thin keft. (That’s why thin kerf exists in the first place,to create less resistance to underpowererd saws) According to the Newton’ Second Law the amount of force is equal to the amount of counterforce, ie full kerf blade pushes the wood harder than thin kerft does. The difference is not small as we need more powerful saws to work with full kerf blade.
So if the blade pushes harder it would throw a piece of wood with higher force.
If you go to the extreme and make the blade razor thin it would not be able to create any kickback, it would just cut into the wood.
I did not expect unbiased answer here though.
jonah
#11 posted 12-05-2017 12:29 AM
I’m not sure where and when you learned your physics, but Newton’s second law of motion describes how the velocity of an object equals its mass times acceleration (F = ma). It has nothing whatever to do with “counterforce.”
It’s not really clear from your “explanation,” but I think you’re talking about the third law of motion, which is that every force results in an equal and opposite reaction.
If you pick up a full kerf blade and a thin kerf one, you’ll see what while the full kerf one is a bit heavier, the difference isn’t all that much as a percentage of its total mass. Thus a full kerf and thin kerf act with substantially similar force on a piece of wood.
I assure you, a 1.5HP electric motor is plenty powerful enough to fling a 1lb piece of wood fast enough to kill you.
View Tony_S's profile
Tony_S
908 posts in 3200 days
#12 posted 12-05-2017 12:33 AM
You’re splitting hairs.
There probably would be some correlation between thin kerf and standard kerf vs. speed of ejection. But the massive amount of different scenario’s that could take place would take an engineer and a mathematician years to calculate.
Kerf width, HP, rpm’s, blade heights, material size, density, any gravitational forces applied….and on and on…
All to find out that the table leg knocked your teeth out at 138mph in stead of 141mph. You still have no teeth.
Tune your saw up properly and use it within it’s capabilities, safely…..it shouldn’t even be a consideration.
-- It is the mark of an educated mind to be able to entertain a thought without accepting it. Aristotle
View Woodknack's profile
Woodknack
12331 posts in 2497 days
#13 posted 12-05-2017 01:44 AM
Lot of interesting thoughts. I’m not sure the question can be answered unless you define what you want to know and how it will be measured. If all you want to know is if a full kerf requires more power to do the same work, assuming all other factors are equal, then yes. But to decide whether that’s more or less safe, you need something to measure.
View knotscott's profile
knotscott
8120 posts in 3493 days
#14 posted 12-05-2017 12:49 PM
I think the danger factor is probably pretty minor between kerf widths. If your saw is underpowered, you might be more prone to push harder with a full kerf blade simply because it poses more resistance, but otherwise I don’t think the full kerf blades are inherently more dangerous. From a safety standpoint, it’s far more important to use good technique, safety devies, have the saw setup well, a sharp blade that’s correct for the task, and to use flat and square stock that doesn’t fight you.
View Kazooman's profile
Kazooman
1115 posts in 2069 days
#15 posted 12-05-2017 01:08 PM
- runswithscissors
Good point. Reminds me of the time when I was a kid when a group of us chipped in and bought a whole watermelon. Lacking a knife we cut it into pieces on the edge of a stop sign. Worked like a charm. I do not recall if it was a thin kerf stop sign or the standard full kerf model. I do recall that it was red.
PS: The stop sign lacked a riving knife and yet there was no kick back. We did use a pair of watermelon Grippers to protect our fingers.
