Miter joints
Forum topic by Walt posted 12-04-2017 12:50 AM 437 views 0 times favorited 7 replies Add to Favorites Watch
View Walt's profile
Walt
249 posts in 2864 days
12-04-2017 12:50 AM
Topic tags/keywords: joining milling
If a picture frame is completed with nice tight miters can the outside of the frame be given a round over or Ogee,Safely. I have a large frame 32×30.5. It is not finished and I planned to do a round over with hand tools. I was asked by someone why didn’t. I use a router I was stuck I have always profiled before assembly . Any info appricated
-- Walt Wilmington Delaware, http://waltlumley@yahoo.com
7 replies so far
woodbutcherbynight
4843 posts in 2434 days
#1 posted 12-04-2017 01:34 AM
I have done this on something at least that large. One problem I have seen is the router bearing can sometimes leave a trail or indentation. Some sanding usually does the trick.
View jbay's profile
jbay
2340 posts in 924 days
#2 posted 12-04-2017 01:46 AM
So, are you going to use hand tools or the router?
Either way, it would be best to clamp a piece of wood (for a backer) even with the ends so that when you come off the corner it doesn’t blow out the perpendicular piece.
View Walt's profile
Walt
#3 posted 12-04-2017 01:53 AM
My concern has always been blowout at the corner I am leaning towards hand tools
View jbay's profile
jbay
#4 posted 12-04-2017 01:59 AM
- Walt
Even with hand tools I would use a backer board.
View sawdustdad's profile
sawdustdad
363 posts in 910 days
#5 posted 12-04-2017 02:23 AM
Deal with the potential for tear out at the corners and rout away! (as long as the assembly is strong enough to be handled for this process).
-- Murphy's Carpentry Corollary #3: Half of all boards cut to a specific length will be too short.
View cabmaker's profile
cabmaker
1735 posts in 2834 days
#6 posted 12-04-2017 12:50 PM
climb cut the corners
View tomsteve's profile
tomsteve
790 posts in 1244 days
#7 posted 12-04-2017 01:23 PM
if you use a router, dont remove material all in one pass. make 2 or 3 passes with the last just a cleanup cut- maybe 1/16-1/8” deep. that, plus the backer blocks at the ends will yield you good results.
