Thickness sander parts
Forum topic by Kohola posted 02-28-2011 09:43 PM 2670 views 0 times favorited 5 replies Add to Favorites Watch
View Kohola's profile
Kohola
4 posts in 2525 days
02-28-2011 09:43 PM
Hi. This is my first post. I am in the process of procuring parts to build a thickness sander and am looking for specifications and a suppliers for various parts. Right now, I’m looking for a DC conveyor motor. Any help much appreciated.
Thanks,
Tim
-- Tim
5 replies so far
View oluf's profile
oluf
260 posts in 2914 days
#1 posted 03-01-2011 03:44 AM
Any corded electric drill will work fine. If a corded tool has brushes it will run on AC or DC, better on DC. You could also use a router or circular saw motor. The electric drill would be my choice because there are so many with variable speeds and the price is right.
-- Nils, So. Central MI. Wood is honest.Take the effort to understand what it has to tell you before you try to change it.
View Elksniffer's profile
Elksniffer
101 posts in 3273 days
#2 posted 03-02-2011 05:40 PM
http://lumberjocks.com/projects/43892
Tim,
This link is exactly what you are looking for, I am in the same design and procurement phase.
I have another lead on some motors to use also so contact if you need more info.
Jeff
Kohola
#3 posted 03-03-2011 03:52 AM
Thanks guys, that is exactly what I was looking for. I called the guy at wondermotors.com and bought a 12v 50 rpm motor from his ebay store. He was very helpful. The motor comes with a controller, and I have a power supply that should work. A bunch of other parts were ordered from surplus center – acme screws, nuts, sprockets, bearings, etc. There are a few more things to get, then I’ll start the build. I’ll let you know how it turns out.
Tim
-- Tim
View bigike's profile
bigike
4053 posts in 3164 days
#4 posted 03-03-2011 05:18 AM
I’m with ya on this, http://www.rockslide.org/drum%20sander.html
heres something also if you look at the liks on the bottom of the screen there should be more.
http://www.woodworkstuff.net/EDTSander.html
on either of these there should be more links or something to help. KEEP us posted or Me anyway.
Kohola
#5 posted 04-18-2013 02:08 PM
Well it’s been a couple years… Just want to let you folks know my sander has been up and running for quite awhile. In fact, I’m on version 2, which I built to enable others to build a similar machine.
The first machine required a bit of welding and some other metal work that I eliminated in version 2. There is still some metal work that needs to be done – the hardest being putting shoulders on acme screws. There are some simple techniques to do that with a bench grinder.
I have pictures of it on my website – shigshop
Tim
-- Tim
