gluing on top of poly or spar urethane
Forum topic by Razorbak91313 posted 02-28-2011 09:44 PM 2332 views 0 times favorited 5 replies Add to Favorites Watch
View Razorbak91313's profile
Razorbak91313
89 posts in 2822 days
02-28-2011 09:44 PM
I know this might seem like an odd question, but can something be glued on top of a poly or spar urethane coat? I am working on a wood and stained glass project and realized that I will end up needing some small feet on the back side but I have nearly finished the my spar urethane coats. The feet do not need to have a great deal of strength to them but I don’t want them just popping off under a little pressure or bump. I was thinking of putting a thin coat of urethane on the back of the feet and then using tiny brats to tack them down while the urethane dries. The brats on their own might not be enough to hold them well and hoping the urethane would dry and bond to the existing coat.
-- Turning good wood into even better wood jewelry. DWWoodCreations.com
5 replies so far
View childress's profile
childress
841 posts in 3720 days
#1 posted 02-28-2011 09:50 PM
I would try double stick tape…
-- Childress Woodworks
View Domer's profile
Domer
252 posts in 3544 days
#2 posted 02-28-2011 10:29 PM
I would call the finish manufacturer.
I had finished a piece before realizing that I needed to add a strip. I called General Finishes and asked them about it. It turned out that I jurist needed to lightly sand the effected area and glue the strip on.
Domer
View rustfever's profile
rustfever
759 posts in 3488 days
#3 posted 02-28-2011 10:50 PM
Mark out the area to be covered by the ‘feet’. Cover surrounding area with blue masking tape. Sand only area to recieve glue. Glue the feet on. Remove the blue masking tape. Let dry per glue specs.
quick and easy.
-- Rustfever, Central California
View Rick S...'s profile
Rick S...
10790 posts in 3211 days
#4 posted 03-01-2011 09:05 AM
What rustfever said!!
Urethane is a Wood Finish, Not a Glue. For the little bit of work involved it’s worth the effort. If it’s not completely dry yet use a Paint Scraper to get the bulk of if off then sand.
I would never try to glue anything to a Urethane or any other kind of finish without taking it down to bare wood. Also some type of Mechanical fastener (Screws Nails) or Dowels as mentioned above would be a good idea.
-- It is not necessary for Some People to turn OFF the LIGHT to be IN the DARK! (Ontario, CANADA)
Razorbak91313
#5 posted 03-01-2011 06:29 PM
Thanks for the info. I really like the idea of taping the surrounding area to help protect it while i sand. The feet are going to be really small – about 1 inch cube – meant more to keep it even when it is hanging on the wall. I will be sure to provide a few pics when I am done. I am still very much an amatuer wood worker but I think this is a nice design, even if it may be a little rough on the details.
