Dome light cover
« back to Coffee Lounge forum
Forum topic by JRsgarage posted 12-03-2017 05:11 PM 331 views 0 times favorited 5 replies Add to Favorites Watch
View JRsgarage's profile
JRsgarage
287 posts in 627 days
12-03-2017 05:11 PM
hi all. i’m changing light bulbs in my house but can’t seem to remove this one particular dome cover. i have several others of same and they all easily slide off when the bottom is screwed off, but this one does not move. anyone experience same? i’m starting to think one of my past tenants glued it on. thanks
-- Two is One, One is None
5 replies so far
View Steve Peterson's profile
Steve Peterson
388 posts in 3200 days
#1 posted 12-04-2017 04:29 PM
Every light of that style that I have ever seen comes off by removing the bottom screw. Maybe you can try twisting the entire glass portion to see if that jars something loose.
-- Steve
View Andre's profile
Andre
2010 posts in 1924 days
#2 posted 12-04-2017 04:48 PM
Sometimes Vise grips solve the problem, or a hammer?
View Lazyman's profile
Lazyman
2387 posts in 1505 days
#3 posted 12-04-2017 04:55 PM
When you remove the nut, does the retaining ring come off or is that what is stuck? Could be that the edge of the ring is caught in a thread. Try turning it or simply trying to carefully pry it out of the thread.
JRsgarage
#4 posted 12-04-2017 06:06 PM
when i remove the screw the retainer ring just slides off. i have few others of same model and they all work fine. the glass dome does not twist or screw onto the main housing. i’ve tapped on it hoping to jar it loose but nothing. i’ve run a thin screw driver around where they make contact but no movement. i’m stumped…
at this point, i’m taping the dome up to lightly crack it off. thanks for the reply/suggestions
View JCamp's profile
JCamp
796 posts in 668 days
#5 posted 12-04-2017 06:30 PM
Only thing I can think is some times folks put a small nut on the bottom of the glass and then cover it over with the round metal dome and the decorative nut
Other than that you might slide a piece of paper and slide all around the top to make sure its not sealed and stuck.
If not that break the glass and buy another lol
-- Whatsoever thy hand findeth to do, do it with all thy might
