Half-Lap Joints
Forum topic by theatrecarp posted 812 days ago 956 views 0 times favorited 8 replies Add to Favorites Watch
View theatrecarp's profile
theatrecarp
2 posts in 812 days
812 days ago
Topic tags/keywords: half lab joints jig question
Hey everybody,
I am new to Lumber Jocks. I am a heatre carpenter and we are building a show with a lot of windows (approx. 30-40) utilizing half lap joints. I was wondering if anyone had any suggestions on how to create a jig. We will be building them out of 1×4. Thanks in advance.
theatrecarp
8 replies so far
View TheDane's profile
TheDane
2675 posts in 1831 days
#1 posted 812 days ago
I have used a tenoning jig to cut them … first, I set the table saw to cut the ‘shoulder’, then use the tenoning jig to whack off the ‘cheek’. Takes a little setup, but once you get the tenon jig dialed in, you can knock them out pretty fast.
—Gerry
View RONFINCH's profile
RONFINCH
142 posts in 1092 days
#2 posted 812 days ago
I would think just a stop block and a dado blade, no jig necessary.
View rhett's profile
rhett
553 posts in 1835 days
#3 posted 812 days ago
You should have the theatre buy you a Kreg jig. I am sure the sets would go together twice as fast.
-- http://www.niceashplanes.com/ http://www.efcabineture.com/
View artthruwood's profile
artthruwood
28 posts in 930 days
#4 posted 812 days ago
Set your dado set as big as it will go then throw your mitre gauge on and nibble away.
The setup stays the same for each mating surface so its not very complicated
-- slowing down with bring you greater speed then going fast
View chrisstef's profile (online now)
chrisstef
5246 posts in 1174 days
#5 posted 812 days ago
ditto on what art said … but if you start getting a lot of tear out on the back end put another board behind it that way your backer board takes the tear out and not your work piece. Good luck.
Welcome to Lumberjocks by the way …
-- "there aren’t many hand tools as awe-inspiring as the #8 jointer. I mean, it just reeks of cast iron heft and hubris" - Smitty
theatrecarp
2 posts in 812 days
#6 posted 812 days ago
Thanks everyone. We have researched all your ideas. We actually have to build 57 plus at 7 different styles. I need a solution that an inexperience student can do. Most of our work force are students doing lab hours.
rhett: the Kreg Jig looks really cool and we will definitely look into it.
art, chris & ron: We have a saw stop table saw and changing a blade is a pain but also we cant really afford to buy a dado blade and if the saw trips buy another one.
TheDane: The tenoning jig looks interesting.
View Kindlingmaker's profile
Kindlingmaker
2646 posts in 1694 days
#7 posted 812 days ago
Do you have a band saw? If so it would be vary easy to set up and make your half lap joints that way and its fast and a little more safe than some TS.
Kindlingmaker
#8 posted 812 days ago
