Cutting board planing advice
Forum topic by mwarning posted 12-03-2017 11:38 AM 718 views 0 times favorited 9 replies Add to Favorites Watch
View mwarning's profile
mwarning
16 posts in 585 days
12-03-2017 11:38 AM
Howdy folks. My wife thought it’d be nice to build some last minute cutting boards from some scrap to give as gifts. I don’t have much time and so I’ll probably just do up some simple edge grain boards. Given my material, I’d prefer to orient the board with the grain running along the short side as seen on the right in the photo below. My planer won’t be able to accommodate it going through in that direction however, so I’d have to rotate it and put it through against the grain. Should I avoid this? I know many people suggest to not send end grain boards through, but I’m wondering about this. I suppose the finish wouldn’t be all that good. Thoughts?
9 replies so far
View Rich's profile (online now)
Rich
3880 posts in 790 days
#1 posted 12-03-2017 11:53 AM
I think it’s going to be a problem if your planer has regular knives. It could even damage your planer.
View Slider20's profile
Slider20
119 posts in 722 days
#2 posted 12-03-2017 01:08 PM
I’ve done that in two cutting boards with a straight knife cutter on my Dewalt DW736, I chamfered the trailing edge and took super light passes, worked fine, it’s certainly not ideal, but flattening by hand was sulo much trouble for me that I decided to risk it.
View bondogaposis's profile
bondogaposis
5088 posts in 2552 days
#3 posted 12-03-2017 01:12 PM
Why don’t you make the the boards longer then cut them to final length after you plane them?
-- Bondo Gaposis
View Tennessee's profile
Tennessee
2893 posts in 2715 days
#4 posted 12-03-2017 01:51 PM
I ran into a guy at a festival with end grain boards – he said he had flattened them with a standard lunch box planer. That was OK and kind of amazed me, until I looked closer and saw a LOT of very small fill points, where he had tearout and had to fill it with putty. I would never send out a board that had putty on the usable face. High strength epoxy, maybe if the hole was small and not in the usual knife cutting area.
I think it depends on the wood you are using. His tearout was only on certain woods. (Sorry I don’t remember which species, but everything in the board was domestic.)
View tomsteve's profile
tomsteve
876 posts in 1420 days
#5 posted 12-03-2017 09:32 PM
this reads like a “hold my beer and start the video” type of thing.
View AlaskaGuy's profile
AlaskaGuy
4786 posts in 2510 days
#6 posted 12-03-2017 10:46 PM
Why don t you make the the boards longer then cut them to final length after you plane them?
- bondogaposis
I agree 100%. But he said “Given my material, I’d prefer to orient the board with the grain running along the short side as seen on the right in the photo below.”
I’m thinking his stock is to short to make longer one to cut up.
View Shamb3's profile
Shamb3
37 posts in 382 days
#7 posted 12-03-2017 11:04 PM
could you build it in 2 halves, plane both halves to the same thickness and glue them together on a really flat surface? I have no experience with this, so that might be a dumb thought :)
Rich
#8 posted 12-03-2017 11:19 PM
- Shamb3
+1. That’s the way to go for sure. Little sanding and he’s all set. While he’s at it, he should work on convincing his wife that he needs a drum sander.
View franktha4th's profile
franktha4th
84 posts in 375 days
#9 posted 12-04-2017 01:16 AM
I have jointed against the grain and it did fine with really shallow passes, but never tried it through a planer. Im with Rich, a drum sander works great for this!
-- Frank, Washington State, https://www.youtube.com/user/franktha4th
