How can I improve this block plane
« back to Hand Tools forum
Forum topic by jtrz posted 12-03-2017 04:32 AM 778 views 0 times favorited 9 replies Add to Favorites Watch
View jtrz's profile
126 posts in 1110 days
12-03-2017 04:32 AM
Topic tags/keywords: plane question
Found this at my great uncles after he passed. I can’t afford to get a high quality plane at the moment so hoping you all can aid me in tweaking this one to improve it’s performance. It’s a stanley and I think it is a part of the handyman or handymade collection whenver they made those. It’s 6 1/2” x 2”
So what do you think? Can I get this thing into good enough shape to get me by until the big bucks start rolling in?
9 replies so far
View Andre's profile
1723 posts in 1742 days
#1 posted 12-03-2017 06:31 AM
Short answer is sure, but do not expect to make shavings in the 1/1000 range. flatten the bottom , sharpen the iron and use it.
View TheFridge's profile (online now)
9114 posts in 1422 days
#2 posted 12-03-2017 07:18 AM
Pretty much.
View fuigb's profile
471 posts in 2894 days
#3 posted 12-03-2017 01:35 PM
IMO… educate yourself about old planes (e.g. “Blood and Gore” for the history of Stanley) and then troll estate sales, flea markets, and consignment stores for low-cost winners. If you even sorta know what to look for and where to do it you’ll eventually find damn good tools for $20 or less. Knowledge, patience, work ethic, and a ten dollar bill are enough to get you you set up with literally the cat’s ass of block planes.
-- - Crud. Go tell your mother that I need a Band-aid.
15250 posts in 2555 days
#4 posted 12-03-2017 04:54 PM
As it’s said, ‘sharp fixes everything.’ In other words, make the cutter as sharp as you know how and the plane will work to the best of its’ ability. It lacks fine adjuster mechanisms, so fettling is trial and error (taps, check cut, more taps, check, etc. etc.). And once it’s set, leave it there.
Good luck!
#5 posted 12-04-2017 02:30 AM
View AESamuel's profile
75 posts in 1159 days
#6 posted 12-07-2017 08:28 PM
All I would do to that is flatten the sole, remove the rust, and get that blade nice and sharp; anything else would be pure aesthetics.
Key with planes like that is not to try and adjust the blade with your fingers, it will only end in frustration. Use a 4oz hammer with light taps to adjust the blade in, and side to side.
View Bill_Steele's profile
269 posts in 1668 days
#7 posted 12-07-2017 09:44 PM
I have a block plane very similar to this (see below). It really does work well if it is sharp and adjusted correctly. I can get fairly thin shavings—thin enough to read through.
I adjust it by first getting it close, and then with light tension on the iron, just tap the heel or the toe on the work bench to adjust the projection of the iron.
View Derek Cohen's profile
Derek Cohen
366 posts in 3905 days
#8 posted 12-15-2017 02:58 PM
There is more you can do.
These block planes have enormous mouths, which makes it difficult to set the blade for a fine cut.
To close up the mouth, you need to build up the floor behind the mouth. This will raise the section upon which the blade rests. I have done this to a LN #103 using brass shim, here …
Regards from Perth
-- Buildiing furniture, and reviewing and building tools at
View jtrz's profile
#9 posted 12-27-2017 12:24 AM
Thanks for all of the tips everyone! Sorry I am so late in replying.
I did a little bit of cleaning, sharpening, rust removal and gave it a go and it work pretty well. I decided against going into a more in depth refurbishing for now though I may to a more in depth sharpening of the iron.
In the meantime I found a few treasures at my grandfathers house that he let me have. Needless to say I am super excited.
Stanley Bailey #5 Jack plane
Stanley Bailey #6C Fore Plane
A Miller Falls I think no. 9 smoother.
Not sure about this one but I think it’s a smoothing plane of some kind. I’ll know more after I clean it up a bit.
Some more block planes. I don’t see any markings but I haven’t looked to hard at them yet.
I asked my grandfather when he bought these and he said they were his father’s so I am thinking a lot of these are from the 30’s. I am going to start a new topic to talk about these new additions sometime soon.
Thanks guys
