Black wood (or synthetic material?) for thin accent
Forum topic by BadgerJoe posted 12-02-2017 08:12 PM 345 views 0 times favorited 8 replies Add to Favorites Watch
View BadgerJoe's profile
24 posts in 1117 days
12-02-2017 08:12 PM
Good Afternoon:
I am planning to build a subwoofer for a relative. The MDF box will be clad in curly maple hardwood. The end grain of the maple will be exposed in some areas, and I’d like to accent it by laminating a very dark (preferably black) material to the interior face of the maple, so that you see a thin black line along all the areas where the end grain is exposed.
I’m looking for a recommendation on a wood or other material that is black, can glue to both maple and MDF and is about 1/8” thick. I can, of course, plane down to that thickness if it doesn’t come in that thickness. I’m looking for something that is readily available and somewhat inexpensive – as apposed to exotic ebony hardwoods. Would black Delrin or some other machineable plastic be a possibility?
Thank you all for your thoughts!
8 replies so far
View bondogaposis's profile
4641 posts in 2288 days
#1 posted 12-02-2017 08:42 PM
Get some wenge veneer.
-- Bondo Gaposis
#2 posted 12-02-2017 09:02 PM
Bondo, thanks for the suggestion. Veneer is a little thiner than I’d like for the accent. Wenge would be a perfect material, but is prohibtive in the amounts that I’ll need – about 10 square feet of something 1/8” thick.
View Tennessee's profile
2828 posts in 2451 days
#3 posted 12-02-2017 09:06 PM
I’ve seen an almost black pressboard in at least one of my big box stores. Not entirely black, but doggone close. I cannot remember which one, but it seems to me it would be the same color all the way through, so if it was say, 3/16” or 1/4”, you could resaw it down as you cut your strips. And I would think it would be possible to dye the pressboard with a water based dye that when dry, would retain its gluing capability.
You can buy a bottle of black water based dye in any craft store for around $3.
View MrRon's profile
4676 posts in 3180 days
#4 posted 12-02-2017 09:41 PM
I agree with the previous poster. A wood like pine died with a black dye or india ink. It could also be Japanned using ammonia (I think that is what the process is called).
View Knockonit's profile
337 posts in 138 days
#5 posted 12-02-2017 09:52 PM
I saw a video where a fella used a thin black accent, i’d say an 1/8 or smaller, i did attempt to contact and see what he had used, but as of yet have not heard back, if and when will advise
#6 posted 12-02-2017 10:00 PM
Thanks all! the black dye idea would work; however, with the sequence of assembly/finishing I have planned, the accent material will get routed after it’s glued up to the maple, so it will need to have a consistent color all the way through.
View Woodknack's profile
11320 posts in 2316 days
#7 posted 12-02-2017 11:13 PM
Look at places like Stew Mac, it sounds like you want something similar to guitar binding.
-- Rick M,
View tomsteve's profile
766 posts in 1155 days
#8 posted 12-04-2017 01:31 PM
just my opinion, but with curly maple, i wouldnt want to use any plastics. my personal preference would be walnut. it always looks nice as an accent to maples
