Hi Spike – You should be able to use regular full kerf blades with that saw, but the thinner kerf blades are easier on the motor. As long as the blade kerf isn’t thinner than the width of the riving knife, all should be fine. The only Japanese blade that I’ve tried is an excellent Tenryu Gold Medal GM25540 40 tooth general purpose blade with a kerf width of 0.111”, which should work out very well if you choose to go with a general purpose blade. The Freud blades you listed are all solid performers within their classifications. I’d also look into blades from Infinity, Forrest, Ridge Carbide, and CMT as possible choices if they’re available to you.
As far as which type of blades to use, its really a matter of preference. There are good arguments in favor of both general purpose blades, and separate specific task blades. My blog about picking saw blades has more detail.
