Any advice for first time veneering?
Forum topic by ScottN posted 02-28-2011 02:50 PM 927 views 0 times favorited 3 replies Add to Favorites Watch
View ScottN's profile
ScottN
261 posts in 2585 days
02-28-2011 02:50 PM
I bought a minimax M16 about 5 years ago and had VERY little use…mainly cutting toe kicks on cabinets.
I still have the original blades that came with it (Olson blades I think). I just ordered a Timberwolf 3/4 3 TPI (PC .032) for my first attempt at resawing.
I’m planning on using some melamine to veneer to,I’ll be sanding off one side of the melamine to expose the particle board.
A few questions come to mind like how do you remove the saw marks after resawing? I have a 37” wide belt sander so I’m not worried about the finished side because after gluing it to the melamine panel I can run it through the sander. How do you get the bandsaw marks out of the side I need to glue?
I don’t have a vacuum press so what type of glue would work the best?
I plan on resawing hickory and about 4” wide book matched. Should I veneer to the thickness of 1/8” or a little thicker to allow for sanding?
-- New Auburn,WI
3 replies so far
View Mark Shymanski's profile
Mark Shymanski
5621 posts in 3618 days
#1 posted 03-14-2011 03:35 AM
You are sanding off the melamine? Why not just get fresh plywood?
ScottN
#2 posted 03-15-2011 01:38 AM
Mark I built the cabinet carcases out of melamine and I wanted to try to veneer the end panel. Instead of trying to veneer over the melamine I was going to run the end panel through my widebelt sander, totally removing the melamine for a better bond. About a 2 min job.
Unfortunately I never tried it, I decided to rearrange some of the stationary tools in my shop and install a new dust collection system. So I put off the veneering for a later date.
-- New Auburn,WI
View Gerry's profile
Gerry
263 posts in 3146 days
#3 posted 03-17-2011 09:18 PM
Scott,
I’m with Mark re sanding off the melamine surface. That being said, if you are determined to do so, the technique I found worked well with plywood was to apply an even coat of Titebond III to both surfaces, let it dry completely, and use a house iron ( or a dedicated iron if you have one) to make the veneer stick. This seems to work well.
Re your first attempt at re-sawing, there are many good guides to band saw set up and re-sawing both here and out on places like u-tube, etc. RE removing the band saw marks, your timberwolf blade should give you a pretty smooth result, so just sanding should do what you need.
Good luck!
-- -Gerry, Hereford, AZ ” A really good woodworker knows how the hide his / her mistakes.”
