How to conceal a thin joint
« back to Joinery forum
Forum topic by wdm posted 12-01-2017 01:53 PM 668 views 0 times favorited 5 replies Add to Favorites Watch
View wdm's profile
wdm
6 posts in 1633 days
12-01-2017 01:53 PM
I had to add about a 2 1/2” piece of wood to the top of an old heart pine exterior door that I am installing so it will fit. I attached it from the top with long screws so it is butted pretty tight over most of the 34” width. Where it’s not tight it’s a very very small crack. I would like to conceal the joint before I paint so when it’s done you can’t tell there was anything added.
Any suggestions as to the best way to accomplish this? Caulk? Using wood filler like sheet rock mud? ??
Thanks! David
5 replies so far
View MrRon's profile
MrRon
5192 posts in 3442 days
#1 posted 12-01-2017 06:40 PM
Any wood filler will work. You could try very fine sawdust with PVA glue or CA instant glue.
View PPK's profile
PPK
1197 posts in 1008 days
#2 posted 12-01-2017 07:39 PM
- MrRon
+1
But don’t use caulk.
-- Pete
View wdm's profile
wdm
#3 posted 12-01-2017 08:55 PM
For most of the joint the wood is butted up so tight there’s no gap to push anything into. However, from experience it will show when painted.
David
View jbay's profile
jbay
2861 posts in 1098 days
#4 posted 12-01-2017 09:26 PM
The only way I have got it not to show, or to telegraph through the finish after a couple of months.
I create a small valley on the seam and fill it with bondo, then plenty of primmer and paint.
The seam will never telegraph through.
View wdm's profile
wdm
#5 posted 12-01-2017 10:47 PM
jbay, I think you’re right. That’s how we fill a line crack in plaster. Could do with wood filler, but its likely to crack over time as the wood shifts.
