Electric motor hums when I plug it in, before I start the switch, but runs fine when I start it
Forum topic by SteveHaf posted 12-01-2017 01:52 PM 390 views 0 times favorited 4 replies Add to Favorites Watch
View SteveHaf's profile
SteveHaf
6 posts in 412 days
12-01-2017 01:52 PM
Topic tags/keywords: scroll saw motor
I have a Delta 40-440 24” Scroll Saw. When I plug it in, the motor hums, before I hit the start switch. When I do hit the start switch, it seems to run fine. Any thoughts on what the cause is and how to troubleshoot and repair?
View verdesardog's profile
verdesardog
171 posts in 2846 days
#1 posted 12-01-2017 02:20 PM
Could be a bad start switch….
-- .. heyoka ..
View WhyMe's profile
WhyMe
1080 posts in 1796 days
#2 posted 12-01-2017 03:09 PM
I don’t believe the motor should be humming before power is turned on. Has it just started doing this?
View Dustin's profile
Dustin
611 posts in 975 days
#3 posted 12-01-2017 03:14 PM
Ground loop?
-- "Ladies, if your husband says he'll get to it, he'll get to it. No need to remind him about it every 6 months."
SteveHaf
6 posts in 412 days
#4 posted 12-02-2017 04:12 PM
I grounded the green wire in the start switch’s box. If it’s a bad start switch, could I use a simple light switch to test it? If yes, I’m not sure how to wire it – there’s a black, red, white and green wire coming into the box
