Carnuba Yes?, Silicone No!
Forum topic by DIYaholic posted 842 days ago 596 views 0 times favorited 6 replies Add to Favorites Watch
View DIYaholic's profile
DIYaholic
7575 posts in 872 days
842 days ago
Looking for input regarding what is recommended to “wax” the surfaces of woodworking machines. What do you use and why? What should be avoided at all costs? Is there anything else I should be aware of?
Just a newbie, setting up shop and wanting to start off right.
Thanks in advance for the help.
-- Randy-- I may not be good...but I am slow!
View syenefarmer's profile
syenefarmer
334 posts in 1277 days
#1 posted 842 days ago
Just stay away from any type of wax with silicone in it and you’ll be OK. Johnson’s Paste Wax is probably the most often recommended wax for CI machines but there are others out there that work just as well.
View Roper's profile
Roper
1333 posts in 1910 days
#2 posted 842 days ago
Johnsons, its quick, easy , and cheap and will protect all your machine surfaces.
-- Roper - Master of sawdust-www.coloradocustomworks.com
View William's profile
William
7179 posts in 1039 days
#3 posted 842 days ago
I use nothing but Johnson’s Past Wax. I use it for one reason and one reason only. It works.
An fellow lumberjock recommended it to me. I tried it. It eliminated the problems I was having using car wax and I haven’t used anything else since. I figure if it works, why take the chance on using anything else that might not.
As a side note.
I use a clean rag to get the wax out of the can each time. That way the wax in the can stays clean and I can also use it as a wood finish when and if I desire as well.
View DLCW's profile
DLCW
503 posts in 851 days
#4 posted 842 days ago
Yep, Johnsons Paste Wax from the local grocery store. Inexpensive and works well. I use it on all my machine table surfaces, including my router table Formica laminate top.
-- Don, Diamond Lake Custom Woodworks - http://www.dlwoodworks.com - "If you make something idiot proof, all they do is make a better idiot"
View Billp's profile
Billp
722 posts in 2397 days
#5 posted 842 days ago
One of the best carnuba waxes I use is called S100 Its a wax sold at Harley Davison Motor Cycle shops. Not cheap I think I paid about $14.00 It works great on metal and on wood. 100% Carnuba.
-- Billp
DIYaholic
#6 posted 842 days ago
Thanks everyone,
I really appreciate all the replies. I have had some of my machines a little while and was hesitant on using anything until I knew for sure.
Again, Thanks. I can now pretend to be the “Karate Kid” (Wax on, Wax Off).
