Does walnut sapwood not take finishes?
Forum topic by MrDan posted 12-01-2017 02:25 AM 1234 views 0 times favorited 11 replies Add to Favorites Watch
View MrDan's profile
MrDan
205 posts in 3317 days
12-01-2017 02:25 AM
Topic tags/keywords: walnut sapwood finishing shellac
Question about walnut sapwood: I have a shelf made of air dried walnut that i just finished making & now I’m trying to finish it but things are not going so well.
My shellac wasn’t coating the lighter sapwood, so I switched to an acrylic finish but that’s not working either. It looks as though the sapwood is unfinished while the dark heartwood is very glossy. The whole thing has about 6 coats already, but the sapwood looks unfinished still.
(The entire shelf was sanded to 220 and wiped clean prior to finishing.)
Has this happened to anyone else? Any ideas?
11 replies so far
View EarlS's profile
EarlS
1135 posts in 2377 days
#1 posted 12-01-2017 02:35 AM
Did you seal it first? I’ve never seen walnut sapwood not take finish but I have seen it soak up polyurethane like a sponge.
MrDan
#2 posted 12-01-2017 03:27 AM
I put 2 coats of shellac on it before i started with the acrylic coats but that didn’t help much. Maybe it’s just way more thirsty? Strange. I’ve never experienced this with any other wood.
View TheFridge's profile
TheFridge
9608 posts in 1515 days
#3 posted 12-01-2017 06:51 AM
Cypress does this as well.
View Loren's profile
10476 posts in 3677 days
#4 posted 12-01-2017 06:59 AM
It’s “pithy” I think, or can be.
View Firewood's profile
Firewood
343 posts in 1663 days
#5 posted 12-01-2017 01:46 PM
I just finished some walnut beds. I put on about 4 coats of waterlox (no sealer) and noticed no issues with the sapwood.
-- Mike - Waukesha, WI
MrDan
#6 posted 12-02-2017 05:02 PM
Bump. Anyone else have a way around this?Additional coats don’t seem to do anything.
Thanks
View OnhillWW's profile
OnhillWW
130 posts in 1261 days
#7 posted 12-02-2017 06:01 PM
It can be a bugger. I use primarily Waterlox as well and my routine is to spend 20+ minutes making top wash applications. I concentrate on areas where it soaks in – sapwood, sometimes crotches and busy grain, keep applying for 20 – 30 minutes concentration on the dryer looking regions. Thirsty sapwood may not look like it has reached the same saturation point as the heartwood but if you have made at least a handful or so of flooding coats it will be fine. I wipe off the entire piece, not to the point of dryness but getting 95% of the finish off and let it sit for 24Hrs. 2nd and 3d coats will now look good in the thirsty areas despite how they looked at the end of the first coat wipe off. I light sand with 600 grit every 2nd coat as well.
-- Cheap is expensive! - my Dad
MrDan
#8 posted 12-02-2017 07:40 PM
Thanks OnhillWW. I suppose I’ll have to change my process when it comes to sapwood. I prefer to spray everything but I’ll try you suggestion next time prior to spraying.
View EricTwice's profile
EricTwice
237 posts in 562 days
#9 posted 12-02-2017 08:05 PM
Walnut heartwood is hard, and rot resistant. Sometimes the sapwood is a little punky and will absorb a load of finish before it starts to get glossy. OnHillWW is correct with his method. You can do the same process with shellac. This will also harden the wood making it more durable.
-- nice recovery, They should pay extra for that mistake, Eric E.
#10 posted 12-03-2017 12:05 AM
Shellac is great for working up to a surface
build because it dries so fast. I know it’s
frustrating to hear it, but it probably just needs
more coats to get a build on the soft area.
The cut edge of a piece of MDF can drink up
an awful lot of shellac I think, for example.
But it will seal and build eventually.
MrDan
#11 posted 12-03-2017 12:49 AM
Thanks a lot for all the input guys, much appreciated!
