Plywood/pine L joint
Forum topic by mgbbob posted 11-30-2017 01:53 PM 467 views 0 times favorited 8 replies Add to Favorites Watch
View mgbbob's profile
mgbbob
6 posts in 2747 days
11-30-2017 01:53 PM
Hi folks, Working on a sliding shelf that will hold a 65 lb. stereo receiver. The shelf is 3/4” plywood L joined to a 3/4” x 1 1/2” pine board. The shelf will slide on 80 lb. rated ball bearing slides. To connect the plywood and the board I have considered pocket hole joints as well as biscuit joints reinforced with glue. I have also considered a continuous spline joint. Any thoughts or recommendations? Thanks ... Bob
8 replies so far
View LittleShaver's profile
LittleShaver
361 posts in 737 days
#1 posted 11-30-2017 02:46 PM
A good, tight glue joint should be adequate. If you want to add some glue surface, rabbit the pine board 1/4 -3/8.
-- Sawdust Maker
View Carloz's profile
Carloz
1147 posts in 709 days
#2 posted 11-30-2017 02:48 PM
Quite hard to imagine what you are trying to make. A sketch would help.
View rbrjr1's profile
rbrjr1
170 posts in 323 days
#3 posted 11-30-2017 07:36 PM
Modern wood glues if applied properly are stronger than the wood they’re joining.
that being said, rabbet joints, biscuits, and pocket hole joints all would be appropriate for that connection.
-- only an idiot dismisses an intelligent statement because they dont know anything about the person delivering it.
mgbbob
#4 posted 11-30-2017 08:57 PM
Thanks guys, I have decided on biscuits. I have the attachment for the Shopsmith and it does a great job. I will post pics.
View ArtMann's profile
ArtMann
1043 posts in 934 days
#5 posted 11-30-2017 10:45 PM
I wouldn’t fool with the biscuits. Just glue and clamp it up. If it is done correctly, you would have to use a lot of violence and a hard heavy object to break the joint. I might consider a few 23 gauge pin nails instead of clamps depending on the finish.
rbrjr1
#6 posted 12-04-2017 10:09 AM
I use biscuits or dados for most joints, mainly because they assist me in assembling the pieces. it’s hard to go wrong with tight joints and clamps.
post some pictures of your work.
mgbbob
#7 posted 12-04-2017 03:33 PM
Hi folks, I glued the joint and pin nailed and it seems great. Added the ball bearing drawer slides and tried it out with the 70 Stereo receiver in place. It works great. I will get some pictures soon. Thanks for the advice.
View rwe2156's profile
rwe2156
3069 posts in 1598 days
#8 posted 12-04-2017 04:57 PM
Depends on the length of the shelf. It can start out nice and in a few months it can be sagging.
If weight is a concern with a shelf, doubling the thickness of the ply is a better solution to prevent sagging.
