router bit id
Forum topic by dhue posted 11-30-2017 05:57 AM 344 views 0 times favorited 2 replies Add to Favorites Watch
View dhue's profile
dhue
13 posts in 645 days
11-30-2017 05:57 AM
Topic tags/keywords: router bits
i acquired a few 1/4 shank bits with a craftsman router i bought on craigslist to use as a fixed in the router table.
a few of these i think i can id but a little extra help wouldn’t hurt. the first two at the top left are maybe tabletop bits? then a dado with no bearing? a straight bit and then two v groove bits with the cutters on the shank. are the cutters there for deep v groove cuts? first bit on the bottom left is a rabbeting bit. next is a cove? then two straight bits. just can’t totally confirm a few…thanks
2 replies so far
View jerryminer's profile
jerryminer
939 posts in 1556 days
#1 posted 11-30-2017 08:49 AM
Top row, left-to-right:
quarter-round with steel pilot, ditto, flush-trim with missing bearing, straight bit, “panel pilot” bit (for cutting through plastic laminate and removing same from sink cutouts and the like, ditto.
Second row:
rabbeting bit, point-cutting ogee, straight bit, ditto.
Personally, I gave up on using steel router bits a long time ago. they dull fast and then burn the work. You might get a little use out of the two straight bits (lower right)—but I would not expect much from the rest.
View dhue's profile
dhue
#2 posted 11-30-2017 12:22 PM
thanks for the information, advice will be heeded.
