Need advise about making a solid walnut front door.
Forum topic by RussellAP posted 11-29-2017 03:27 PM 449 views 0 times favorited 7 replies Add to Favorites Watch
View RussellAP's profile
3103 posts in 2218 days
11-29-2017 03:27 PM
Topic tags/keywords: walnut wood door
Guys I’m thinking of making a solid walnut front door. I purchased some walnut from a small local mill about 4 years ago and I’d like to get it out of my shop, it takes up too much room.
This walnut is 5/4 and smooth and flat with some beauty marks. It’s from a record walnut here in KC and I got the primary crotch pieces.
So my question is this. Would you make the door 5/4 or would you layer the walnut to 2.5’” thick. I thought about how I’d do it, but the only thing that comes to mind is to glue it with some buscuits or even large dowells.
How would you do it?
7 replies so far
View Greg In Maryland's profile
Greg In Maryland
553 posts in 2930 days
#1 posted 11-29-2017 07:14 PM
Hi Russel,
I can’t possibly provide any sage wisdom for your delemma. But if you want me to stop by and help you get that lousy walnut out of your workshop, I’m up for a roadtrip.
View Loren's profile
10089 posts in 3580 days
#2 posted 11-29-2017 10:12 PM
Google “stave core door”.
View John's profile
242 posts in 1514 days
#3 posted 11-29-2017 10:15 PM
An entry door os typically 1.75 up to 2.25. If you go thinner you will have issues finding hardware.
An old timer once told me the reason doors are that thick is because the panels are actually two seperate panels inside and outside that aren’t glued together, so as to facilitate wood movement with the differences in temperature inside and out.
I dont know how true that is but it makes sense to me, and I intend to do just that when i finally get around to doing my front door.
-- I measured once, cut twice, and its still too short...
View pintodeluxe's profile
5592 posts in 2745 days
#4 posted 11-29-2017 10:32 PM
Here’s what I did…
Mortise and tenon construction with two layers of 5/4 lumber. It finished out at 1-3/4” thick, which is standard for entry doors.
View John's profile
#5 posted 11-29-2017 10:46 PM
He’s right. I was thinking commercial doors. Most are 1.75 with some up to 2.25. A typical house door is 1 3/8 with exterior doors at 1 3/4
View AlaskaGuy's profile
3980 posts in 2241 days
#6 posted 11-29-2017 10:57 PM
It sounds to me like he asking about making a solid slab door. But, who knows with the lack if information in his post.
View Knockonit's profile
334 posts in 134 days
#7 posted 11-29-2017 11:45 PM
i built a large 42’’ wide x 7 ft tall for my joint, used a marine plywood core, then layered each side with some knotty alder i milled to tongue and groove, each side of door has a different pattern, even put a speak easy window in it.
Door is about 2.5 inches in thickness, i used 4 4.5’’ ball bearing hinges, with ball catches for latch it to a 5/4 alder frame with approximately 1 ft sidelights, all frame and misc. out of knotty alder, threshold is out of red oak. door unit has a transom over it at about 1 ft or so,
door here in arizona has stayed extremely stable, love the ball catches, the hold it closed securely, has a fancy handle entry set the ole gal picked out. In the speak easy window, i put two twisted wrought iron bars for looks, the inside has a small door for speak easy, kinda not finished yet,
if i had to do over, i might use a rickson pivot, did that on another clients door and wow, wow, what a easy open and close, a breeze can move it.
good luck with the build, i’ve a mesquite one in the works for first of year, gonna be a monster 9 ft tall, and almost 5 wide, gonna be a dandy, just need me four men and twent y boys to move it around.
again looking good
