| Forum topic by Beginningwoodworker | posted 817 days ago | 1135 views | 0 times favorited | 24 replies | ![]() |
817 days ago |
Topic tags/keywords: blade I pick out three blades that I like for my RAS, I am wondering which is the best out of the three. 1. Forrest WW08607100 Woodworker I 8-Inch 60 Tooth 5/8-Inch Arbor 3/32-Inch Kerf Circular Saw Blade 2. Freud LU88R008 8-Inch 48 Tooth ATB Thin Kerf Crosscutting and Ripping Saw Blade with 5/8-Inch Arbor and PermaShield Coating 3. Freud LU83R008 8-Inch 40 Tooth ATB Thin Kerf Combination Saw Blade with 5/8-Inch Arbor and PermaShield Coating -- CJIII Future cabinetmaker |
24 replies so far
#1 posted 817 days ago |
The Forrest blade says “For Radial Arm Saw or Table Saw Use,” right on it. That’s NOT the Forrest blade I would suggest you consider. They make one that is ONLY for RAS’s. For that one, you have to call them, directly, and talk with … well …. Charles :-) If you can afford that one (I think it IS $90, also), it’s the best. If not, I’d probably buy the Freud LU91R008, for $58. It has that negative hook angle that is really important to prevent the thing from “self-feeding” on you. -- -- Neil |
#2 posted 817 days ago |
I’d also suggest looking at the blade topics on the Delphi Radial Arm Saw Frequently Asked Questions page: http://people.delphiforums.com/snotzalot/sawdust/faq.htm Good luck ! -- -- Neil |
#3 posted 817 days ago |
Neil what model Forrest blade do you have? -- CJIII Future cabinetmaker |
#4 posted 817 days ago |
Since a RAS is rarely used to rip, a combination blade is not always a good idea. You want a good crosscut blade, and unless you have a really underpowered saw, thin kerf isn’t the way to go. Full kerf is more stable and produces better cuts. Negative hook is great if you can get one in your price range, it will make the saw safer. But I have no trouble at all with a good Diablo crosscut blade with a standard hook. Buy the best you can afford and use the saw properly and you can’t go wrong. -- It's the best woodworking show since the invention of wood... New episodes Wednesdays at: http://www.stumpynubs.com |
#5 posted 817 days ago |
I have a 1/2 hp RAS. -- CJIII Future cabinetmaker |
#6 posted 817 days ago |
It’s a Woodworker I. BUT … it’s specially made FOR the RAS, and HAS TO be ordered directly from Charles Bazikian, AT Forrest: [800-733-7111 extension 314] Look at this page, where it says, “Parts to restore a DeWalt radial arm saw” -- -- Neil |
#7 posted 817 days ago |
If you can afford the Forrest blade (you REALLY should talk with Charles, directly), then I’d get it. If not, then the Freud I linked to is probably your best bet. But Mr. Sawdust …. ONLY recommends the RAS-specific Forrest blade … if you want to follow HIS advice ;-) -- -- Neil |
#8 posted 817 days ago |
The MMB (yours) is a 9” saw. If you get an 8 inch blade, then you’ll spin it easier, and won’t HAVE to worry much about the thinner kerf. Worst that happens is … you have to use a slower feed rate. To ME, that’s perfectly okay. -- -- Neil |
#9 posted 817 days ago |
Another good one, Charles, for $40: http://www.amazon.com/Freud-LU83R008-Combination-PermaShield-Coating/dp/B00020JOA0 -- -- Neil |
#10 posted 817 days ago |
Yes my is a 9’’. I really like forrest blades. -- CJIII Future cabinetmaker |
#11 posted 817 days ago |
Charles – As has been mentioned on other forums, you need a hook angle of no more than 5°….less is great. The LU88 (+15°) and the LU83 (+10°) are great blades for a TS, but have too steep of a hook angle for a RAS. -- Happiness is like wetting your pants...everyone can see it, but only you can feel the warmth.... |
#12 posted 817 days ago |
And … as I’m fond of saying … I’d take Scott’s advice on this, instead of mine ;-) So … I think we’re back to Freud’s LU91, or the Forrest. ‘Zat sound right, Scott ? -- -- Neil |
#13 posted 817 days ago |
Neil, I really like the Forrest. -- CJIII Future cabinetmaker |
#14 posted 817 days ago |
Forrest blades are the best!! -- Matt Garcia Wannabe Period Furniture Maker, Houston TX |
#15 posted 817 days ago |
LOL….yeah, those are both great choices! -- Happiness is like wetting your pants...everyone can see it, but only you can feel the warmth.... |
| Forum | Topics |
Woodworking Skill Share
8797 |
Woodturning
224 |
Woodcarving
28 |
Scrollsawing
61 |
Joinery
82 |
Finishing
1534 |
3553 |
15803 |
Hand Tools
2038 |
Jigs & Fixtures
496 |
Wood & Lumber
2844 |
809 |
Focus on the Workspace
903 |
766 |
Woodworking Trade & Swap
2740 |
LumberJocks.com Site Feedback
1547 |
Coffee Lounge
6163 |
