DC-380 Planer question
Forum topic by pbeamtn posted 02-26-2011 02:43 PM 2760 views 0 times favorited 4 replies Add to Favorites Watch
View pbeamtn's profile
pbeamtn
13 posts in 3288 days
02-26-2011 02:43 PM
Topic tags/keywords: dc-380 planer outfeed roller g1021
So I finally stepped up and bought a “real” planer to replace the Delta 22-560 I have had for the past 10 years. I purchased a Delta DC-380 15” planer off of Craigslist, but it needs a little TLC. I noticed the outfeed roller has a polyurethane coating that is worn, so I looked to buy a replacement. I first ordered an real Delta part, but it was backordered. I noticed the Grizzly G1021 is almost identical, except for the stand, so I ordered an outfeed roller from Grizzly, which I have just received.
To my surprise, the Grizzly roller is solid steel. It appears to be the proper diameter, and it looks like it will fit, but I have never seen a solid outfeed roller before. Is this the right roller for my planer, or do I need to return it and wait for the actual Delta part to become available?
View therookie's profile
therookie
887 posts in 3031 days
#1 posted 02-26-2011 04:27 PM
Well if it were me, I would try it out and see if it works, then if it dosent return it and wait for the real part from delta to become available.
-- http://aewoodworks.webs.com
View sawdustphill's profile
sawdustphill
53 posts in 2894 days
#2 posted 02-26-2011 05:53 PM
my powermatic 15” planer has a solid steel outfeed roller it works real fine. have had it for almost 13 years
so I would try it and if it works use the steel ones last a lot longer than the (poly) rubber ones
had one of those on a craftsman, it didn’t last very long.
pbeamtn
#3 posted 02-28-2011 03:29 AM
It is good to hear the Powermatic has a solid outfeed roller. I guess I will give it a try
pbeamtn
#4 posted 03-07-2011 05:33 AM
This is probably more for posterity. I put a solid G1021 outfeed roller on my DC-380, and it fits and works. The roller pressure settings from the G1021 manual are more applicable than the DC-380 as the solid roller takes a bit more pressure to not slip.
