Veneer Thickness - if it has to be < 1/8", how do they do this?
Forum topic by WalkinWoods posted 11-27-2017 05:40 PM 1205 views 0 times favorited 3 replies Add to Favorites Watch
View WalkinWoods's profile
WalkinWoods
6 posts in 305 days
11-27-2017 05:40 PM
I’ve read a lot of posts pretty clearly saying you shouldn’t use veneer thicker than 1/8”. Does that apply to stave core door construction?
The reason I ask is these guys advertise 1/4” thick veneer on their stave core stiles. See http://www.wolflumber.com/stave-core-stiles. Any concerns about that?
3 replies so far
View Loren's profile
10477 posts in 3768 days
#1 posted 11-27-2017 06:44 PM
I think in that case the substrate is going to move
with the “veneer” so it shouldn’t be a problem.
If veneer is thin enough (quite thin) it won’t move
in width when glued to a substrate that doesn’t
move like plywood or mdf.
WalkinWoods
6 posts in 305 days
#2 posted 11-28-2017 09:54 PM
So the veneer problem (i.e. needing to keep the veneer less than 1/8”) only applies to MDF or plywood substrates?
Then constructing a table top out of thicker 1/4” material glued to, for example, a fir substrate would be fine?
#3 posted 11-28-2017 10:34 PM
Loosely, yes.
Moisture content and using species that move
similarly would matter. The grain would also
have to all go the same way.
