Restoring an old handsaw
« back to Hand Tools forum
Forum topic by Cbastiaan posted 11-27-2017 05:32 PM 549 views 0 times favorited 3 replies Add to Favorites Watch
View Cbastiaan's profile
Cbastiaan
7 posts in 381 days
11-27-2017 05:32 PM
Topic tags/keywords: hand saw handsaw nuts bolts
I’m going to restore an old handsaw, but the bolts used in this saw, do not have a slot for a screwdriver.
Is there anyone how could help me with what kind of tool, tip I can remove them?
I always could make my own slots, but I rather remove them as the came.
Any help is appreciated.
See the pictures below
3 replies so far
View MrRon's profile
MrRon
5192 posts in 3443 days
#1 posted 11-27-2017 09:01 PM
I would file the head off and replace them with screws; they are probably rivets, not screws.
View chrisstef's profile
chrisstef
17761 posts in 3206 days
#2 posted 11-27-2017 09:08 PM
You can try and epoxy a nut onto them so you can turn the nut with a wrench. If theyre peened rivets that aint gonna help though. If theyre peened no other way than drilling them out.
View bandit571's profile
bandit571
21753 posts in 2883 days
#3 posted 11-27-2017 09:47 PM
Those are two piece rivets, that snap together. By now, they are rusted solid. Drill just enough to pop the head off on one side. Then use a pin punch to drive the rest out the other side. Replace with regular saw nuts. You can find an old rusty junk saw to reuse the bolts from….or buy a set off of ebay.
They will not twist apart, as they are a press fit. You could get a pair of diagonal pliers under the head, and try to pry them apart…...mars the wood way too much. Just drill them out like you would with pop-rivets.
